Author Topic: Need some Help?!  (Read 1860 times)
Offline cullygti
Re: Need some Help?!
« Reply #10 on: 06 June 2012, 00:06 »
liking the r32 rep and them wheels i dont like them but do at the same time  :grin:
Offline barrym381
« Reply #11 on: 06 June 2012, 00:27 »
make up your mind  :grin: :grin:
Offline stfc_gti
« Reply #12 on: 06 June 2012, 11:45 »
how about secondary air pump? expensive to fix?
Nope they tend to be noisy for the first 30secs (they switch off then), mine is and I just live with it.
same here.
2002 1.8T GTI AUM, Standard (not for much longer)
jockgti
« Reply #13 on: 06 June 2012, 11:58 »
secondary air pump can be repaired or removed,i've removed mine and all hoses and stuff that go with it,or you can remove pump drill out old aluminium rivet things and replace with screws and then put it back on
Offline ENGWootton
« Reply #14 on: 06 June 2012, 18:47 »
@Jockgti. Just wondering whether either are expensive or hard to fix?
Regards.
jockgti
« Reply #15 on: 06 June 2012, 19:13 »
i did both and i'm useless at working on cars so no,and to remove the pump costs 20 quid for a blanking plate or to remove and fix costs the price of 8 or 10 screws and bolts,fiver at most,if you remove the pump it does throw up an error code for improper flow which you can ignore or get mapped out
Offline JimBR
« Reply #16 on: 06 June 2012, 21:20 »
If your completely useless with cars just pull the connector out the pump  :grin:
You'll eventually want it mapped so they can map the code out then  :wink:
Offline monty9120
« Reply #17 on: 07 June 2012, 09:41 »
i wondered what that noise was haha
