Author Topic: Need some info on the bumper? Screw its only money! NEW Purchase!  (Read 3020 times)
Offline clipperjay
Can someone check the spacing (CM) of those mount holes on a genuine bumper for me?
The fronts I need to establish if the general mounting brackets will fit my bumper?
I'm only interested in the main four holes and the one on the right next to right top mounting hole.
If the ones on the wing are stock then in theory all brackets should fit?
Offline Mr Blue
Re: Need some info on the bumper?
« Reply #1 on: 06 June 2012, 00:35 »
Pattern brackets are shorter in material.
A pattern bracket can work on genuine bumpers but only be screwed by the top holes. Still does the job.
So im guessing the genuine brackets can screw into the top holes only. You might need some washers.
Then you could drill holes into a genuine bracket for the bottom two. copy the screw holes from the pattern to the genuine.
SEAZY
 :smiley:
Offline clipperjay
« Reply #2 on: 06 June 2012, 09:18 »
Yeah thats an idea, the mounting holes look simular would like to confirm the dimensions off a gen bracket though?
Offline clipperjay
« Reply #3 on: 06 June 2012, 18:30 »
Oh well what can you do when no one gives you simple info you need?????????????????????????????
You go out and buy a gen bumper in Atlas grey of course!  :tongue:
Just picked it up screaming buy me as it was in Atlas grey!
Not perfect as there is a scuff, but painters will sort that out quick time.
Both fogs are smashed, but got a spare one chucked in for free I have now three right handed fogs just need a lefty  :grin:
Bumper Iron is solid no rust for a change! Even came with the chassis mounting legs  :shocked:
Splitter is in okay shape which was chucked in aswell  :cool:
Offline Jimmyrallye
  • 20vt goodness
Good find :) just had my back bumper of all all my brackets sound but still got a slope ... Hacksaw out tomorow and move the quatre bracket up 20mm
Offline Mr Blue
Sorry Jay couldn't find my spare set of bumper hangers to measure. No way was i unbolting mine  :grin:
Offline X4MGS
  • VAG Parts SNOB!!!
Dont start hacking things until you have found out why it's drooping... if it's not the Bumper Sliders I would be looking at the bumper metal frame work...
You may just need to adjust it with washers etc..
Sorry Jay,
been to busy sending them out today to have time to sit and measure one up.... You have them sorted now & you could measure your own now!!  :laugh: :laugh: :laugh: :laugh:
For More Info Click To See;
Offline clipperjay
Its fine guys it is sorted now the difference is 2" I can drill a new bracket to match as gen bracket mounts are longer.
Well Guess the after market one is for sale now  :grin:
