Author Topic: brake problems :(  (Read 2010 times)
Offline terryuk
brake problems :(
« on: 05 June 2012, 16:57 »
for people that have been reading on the tdi section iv fitted another turbo to my car and i have no boost at all so iv looked into this and found out the n75 has had its day i think ? its sucking but extreamly lightley and i know i should not but iv still had to use the car with the turbo not working at the mo and this morning the brakes felt a little hard after i dabed them so i pressed the peddle a few times .. peddle goes rock hard and almost no braking at all .. drive down the road and they come back ?? is this the survo now as well or has the vac system got something to do with the brakes ?
thanks for reading guys
Offline stevelfc
Re: brake problems :(
« Reply #1 on: 05 June 2012, 19:14 »
sounds like servo problem
Offline scarr89
  • Mk4 Golf, DERV FTW!
« Reply #2 on: 05 June 2012, 21:31 »
Which it was.  :wink:
Offline ReadieeVTS
« Reply #3 on: 05 June 2012, 21:51 »
I had these symptoms but my brakes were spongey, I changed n75 valve and it wasn't that. It turns out to be the actuator on the turbo was seized.. Check that only takes mins mate.
Offline terryuk
« Reply #4 on: 06 June 2012, 13:39 »
smiley2 iv found the leak full strong boost and brakes are good now thanks the pipe from my vac pump had a split and becaues my old actuator was pants and very week it did not show up till iv fitted the new turbo smiley2 thanks so much guys iv been on it all weekend and have the biggest smile now smiley2
Offline Simpson GTI
« Reply #5 on: 06 June 2012, 13:41 »
I had this last year on my 2002 GT TDI 130. It happened a couple of times randomly and when I released the pedal and pressed down again all was ok. Quite scary though!
Then one day the pedal went rock hard with almost no braking at all, in traffic and it wouldnt go away. My local specialist thought it was vacuum pump but the vacuum was good when the pipe was removed. It turned out to be the servo, once they changed the servo all has been great since. They said that they don't do many, but about the same time they had a couple of Audi A4's do the same thing.
Yours could be the vacuum pump, but be ready for it being the servo.
