Author Topic: brake problems :(  (Read 2754 times)
Offline terryuk
brake problems :(
« on: 05 June 2012, 16:56 »
for people that have been reading iv fitted another turbo to my car and i have no boost at all so iv looked into this and found out the n75 has had its day i think ? i know i should not but iv still had to use the car with the turbo not working at the mo and this morning the brakes felt a little hard after i dabed them so i pressed the peddle a few times .. peddle goes rock hard and almost no braking at all .. drive down the road and they come back ?? is this the survo now as well or has the vac system got something to do with the brakes ?
thanks for reading guys
Offline old_n07
Re: brake problems :(
« Reply #1 on: 05 June 2012, 17:13 »
The servo is vacuum opperated, as you are having problems with the N75 and the brakes have you checked all the vac lines for splits, all the connections are correct and on fully, the one way valve is in the correct orientation.
Quote from: mikemk4golf
Hey you're a moderator, I want a serious answer not someone who takes the piss!
Grammar is the difference between Helping your Uncle jack off a horse and Helping your Uncle Jack off a horse.
Not so standard Gt TDi
Cluster Mods FAQ | Miles to Empty Guide
Offline terryuk
« Reply #2 on: 05 June 2012, 17:36 »
im going to check the vac pump now and all the lines  give me 10 mins thanks terry
Offline terryuk
« Reply #3 on: 05 June 2012, 18:05 »
your a legends :) iv found the leak full strong boost and brakes are good now thanks the pipe from my vac pump had a split and becaues my old actuator was pants and very week it did not show up till iv fitted the new turbo :) thanks so much guys iv been on it all weekend and have the biggest smile now :)
Offline old_n07
« Reply #4 on: 05 June 2012, 18:45 »
Glad you've sorted it out :afro:
