Author Topic: turbo chatter  (Read 4388 times)
Offline GTIcheeseman
turbo chatter
« on: 05 June 2012, 14:59 »
What is it that makes that chatter or flutter is it an external wastegate?
Offline Chris#101
Re: turbo chatter
« Reply #1 on: 05 June 2012, 16:42 »
Turbo chatter is the turbo stalling spinning one way to the other very quickly if I remember correctly!
Vaccum is the cause to this I believe or if you dont any sort of dump valve
          2003 1.8T: R-tech Live Cutom Stage 2 remap: N249 Bypass : Forge T.I.P : Forge 007p  : Forge Actuator, yellow spring : Toyosports F.M.I.C : Toyosports C.A.I :        PCV simplified - oil catch can : 42' Draft 3" turbo back non res exhaust system : Devils own W.M.I : 231bhp & 258lbs-ft
Re: turbo chatter
« Reply #2 on: 05 June 2012, 16:46 »
So when your hear these cars just means they don't have a dump valve don't seem safe
Offline Dolly
Re: turbo chatter
« Reply #3 on: 05 June 2012, 16:59 »
if what i understand is right, you cant have external waste gates any more, well not new cars, something to do with the fact your putting exhaust gas (emissions) into the atmosphere unregulated?
chatter on the bmw twin turbo petrols is the internal waste gates being loose, they need adjusting
Offline conor1
Re: turbo chatter
« Reply #4 on: 07 June 2012, 18:57 »
wrong there is no way the tubo spins one way to the other very quickly do you know how many rpm's a turbo does i guess not. it is the noise of the air being pushed back against the turbo blades but in no way is stoping the turbo spinning or reversing this is caused by running no dump valve.
Offline tech1889
  • Mk2 GTI FTW !!
Re: turbo chatter
« Reply #5 on: 07 June 2012, 19:39 »
My daily chatters very loud i love it  :evil: all i did was remove the turbo you cant really do this on vag engines as they run recirc turbos
Offline Gambit
Re: turbo chatter
« Reply #6 on: 08 June 2012, 09:41 »
aye its just air being pushed back over the turbo veins the wrong way. i run without a dumpvalve on my impreza - car is actually a bit snappier changing between the gears without the dumpvalve
Offline Wazzzer
  • Golf GTI 1.8T AGU
Re: turbo chatter
« Reply #7 on: 08 June 2012, 15:00 »
It's fine for Garrett or bigger turbos but not for the K series turbos really. I used to love the sound of my Escort, just had a cone filter directly on the side of the turbo inlet and no DV lol
Offline scarr89
  • Mk4 Golf, DERV FTW!
Re: turbo chatter
« Reply #8 on: 08 June 2012, 16:37 »
Would have loved to see that!  :laugh:
Is turbo chatter the same as 'turbo bark'. On my bros DERV he has a miltek decat DP, 2.5" and when changing gear and lifting off it makes some sort of owl noise...Is this the sound you guys get to? :undecided:
Offline tech1889
  • Mk2 GTI FTW !!
Re: turbo chatter
« Reply #9 on: 09 June 2012, 20:02 »
thats chatter yer mate,, my turbo just has a airfilter straight on end of it.. k series turbos can chatter but no point
