Author Topic: weak k03 actuator  (Read 2975 times)
Offline GTIcheeseman
weak k03 actuator
« on: 04 June 2012, 20:23 »
I have a k03 and was bored so was checking my car over, and I can move my actuator with my hand but with my k03s on my shelf that don't move so easy with my hand is that right? Or has it been worn out inside
Offline Chris.
Re: weak k03 actuator
« Reply #1 on: 04 June 2012, 20:24 »
Probably weak like you say.
Click For Build Thread
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #2 on: 04 June 2012, 22:07 »
Welcome to the Forge club  :wink:
Offline littco
« Reply #3 on: 04 June 2012, 22:14 »
Weak actuator isnt necessarily a problem, it stil opens and closes as it would if was new . However, when you run high boost levels with a stg2 the extra force put on the wastegate from the high exhaust gasses pushes the wastegate open as the weak actuator can't keep it closed. This results in boost tapering off artificially quickly at higher rpm. Fitting a forge or uprated actuator keeps it closed and more power can be made by the turbo.
« Last Edit: 05 June 2012, 17:19 by littco »
« Reply #4 on: 04 June 2012, 22:19 »
Will it be ok for a month? I'm gonna be getting my k03s rebuilt also I have pmd you about a rebuild lo
Offline Chris.
« Reply #5 on: 04 June 2012, 22:24 »
Be fine. Just stick a forge one with yellow spring on your k03s
« Reply #6 on: 04 June 2012, 22:27 »
Good :) that will be why my boost is funny
« Reply #7 on: 04 June 2012, 22:39 »
Need my k03s rebuilt with forge actuator :)
« Reply #8 on: 04 June 2012, 23:00 »
Could I put the k03s on my k03 ?
Offline Chris.
« Reply #9 on: 04 June 2012, 23:34 »
Sometimes, depends if brackets are the same
