Author Topic: what should engine temp be?  (Read 1603 times)
Offline GolfGL
« on: 03 June 2012, 22:10 »
Hi ive just done my first long journey and the gauge read between 75-90 oc. now this was at a steady 60-70 miles an hour. all my previous vag cars have read a static 90 oc one warm so is this normal for a gti 8v?
Also how big is the petrol tank and what is the best speed to maximise mpg?
Thanks
Adam
Audi TT 3.2 24v v6 2005 - The Sloth - Weekends
VW Golf 2.0 8v GTI 1996 - Lemonade II -Daily
MNR Vortx Yamaha R1 2009 - Track days
Sold Seat Leon Cupra R 225 -LM04 NDE "Lemonade"
Offline itavaltalainen
Re: what should engine temp be?
« Reply #1 on: 03 June 2012, 22:13 »
Re: temperature - your thermostat needs replacing. Easy job on VW 827 based engines :)
Re: maximising mpg - 50 mph - no aircon etc.
Offline GolfGL
« Reply #2 on: 03 June 2012, 22:23 »
You think its stuck open then?
adam
Gavv8
« Reply #3 on: 03 June 2012, 22:30 »
Fairly easy job on an 8v.
Offline Bandit127
« Reply #4 on: 03 June 2012, 22:33 »
adam
Yes. I am going to crawl under mine tomorrow to (hopefully) fix exactly the same fault.
While you are driving with a stuck open thermostat you will be using too much petrol. The car takes a long time to get up to temp - especially noticeable on short journeys.
And when you are driving at 75° the oil will be thicker than it should be (at 90°) so will create drag and further reduce your mpg.
My AGG did a trip from Warrington to Hedge End (about 220 miles) with an average of 46.6 mpg and 60 mph the other day - a record for me and I was well chuffed. It was a warm day so the temp was at 90 most of the time which must have helped.
Offline GolfGL
« Reply #5 on: 03 June 2012, 22:46 »
As its cheap i might as well just get a new one and put it in. hopefully will improve the mpg as it seems terrible but as my mfa display is broken im not entirely sure what its getting.
Gavv8
« Reply #6 on: 03 June 2012, 23:07 »
I usually get 35-38 .
