Author Topic: Wishbone bushes done steering wheel now off center??  (Read 1960 times)
Offline AD1.8T
As above any ideas ? My mate recons the ball joint bolts may be slightly miss angled but im not sure any ideas before i get it tracked
Re: Wishbone bushes done steering wheel now off center??
« Reply #1 on: 03 June 2012, 21:24 »
When you get the tracking done they should be able to straighten the steering wheel.
Offline AD1.8T
« Reply #2 on: 03 June 2012, 21:36 »
I didnt want to get the tracking done if it can be helped as it was fine before hand surely its something we have done wrong ?
Offline Bandit127
« Reply #3 on: 03 June 2012, 21:47 »
Putting new wishbones on my old Omega put the tracking out by a country mile. You would have thought that the same parts were made to the same drawing by whoever makes them. Not in that case.
So it likely nothing is 'wrong' - just different. You should check everything is tight and then get the tracking done. Camber too probably...
Offline AD1.8T
« Reply #4 on: 03 June 2012, 22:09 »
Lol yeah ive had enough of laying on my back under the car for the last 2 days everythings torqued up ect so im letting someone else do the dirty work tomoz and getting it all done ! I didnt change the wishbones though i just did the bushes but regardless i was messing about with the front end of the car ...
« Reply #5 on: 03 June 2012, 23:35 »
Changing just the bushes could affect the camber / tracking so well worth getting it checked.
Offline xxChrisxx
« Reply #6 on: 04 June 2012, 09:07 »
You always need to get it done if you change any of the suspension. As it will always alter the tracking to some degree.
Offline AD1.8T
« Reply #7 on: 04 June 2012, 12:02 »
3 garages later and tyrelands the only one who can get her on the ramp  :laugh:
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #8 on: 04 June 2012, 14:01 »
when I had my TT arms fitted both front wheels pointed out so far they didn't even register on the gauges lol
Your camber won't be affected as there is no adjustment on the Golf as standard (apart from moving the subframe slightly) but your tracking will probably be affected due to tightening it all back up
Offline AD1.8T
« Reply #9 on: 04 June 2012, 14:11 »
Haha yeah mine was 9mm out i think they said! all fine now though and the car is alot stiffer ive now done wishbones, top mounts and rear axle only the dogbone left really  :smiley:
