Author Topic: door skin wiring loom  (Read 761 times)
Offline enyap
« on: 03 June 2012, 12:02 »
hi all, i'm currently removing the O/S inner door skin plate on the golf and replacing it with a new one (with a working electric window  :grin:) but i'm having a bit of trouble locating the connection point of the wiring loom of the plate. anyone removed this before??
Offline MC_PEA
Re: door skin wiring loom
« Reply #1 on: 03 June 2012, 14:10 »
Offline enyap
« Reply #2 on: 03 June 2012, 16:59 »
cheers, found it in the end, got the new plate fitted in and the new loom wired up, but the central locking and electric windows are now only working intermitantly  :angry: any techniques for improving the terminal connections anyone??
Offline enyap
« Reply #3 on: 03 June 2012, 21:27 »
this has turned into a real problem now, i changed the wiring loom over from the new plate as i thought it may be faulty and put on the old one which i knew worked fine, after checking it all throughout the refitting, everything seemed to be working fine. however when i got the doorcard back on, both window switches, and the remote central locking failed to work  :angry: i have checked the fuses and all seem fine, got soaking wet doing this today and i am worse off than when i started!  CAN ANYONE HELP??
