Author Topic: Timing belt concerns....Digifant  (Read 1865 times)
Offline wolfsburgsfinest
  • Fortune Favours the Brave
« on: 02 June 2012, 18:15 »
Any advice appreciated on this issue.
Would this timing procedure be ok?
I have been trying to set the timing on my golf. This is the procedure I used, I have not tensioned the belt yet.
I used a rod placed down the spark plug hole in number 1 cylinder to find TDC. I am having difficulty removing the green plug which shows the TDC marking. It is rock solid, wont budge at all!!
I then aligned the camshaft sprocket marking with the cylinder head flange. As shown in the haynes manual. The intermediate shaft sprocket punch mark was aligned with the crankshaft pulley marker.
I have a question though, with the the distributor. I have not touched or loosened the distributor. I removed the HT leads and as I was turning the intermediate shaft the rotor arm was prefectly aligned with a mark on the edge of the distributor. Which when i placed the dizzy cap back on was aligned with the  number one point for the HT lead. The intermediate shaft aligned with the crankshaft pulley perfectly as the number 1 cylinder was at TDC.
Does this procedure sound ok?? Everything seem to line up, but I just cant get the green plug off to check the TDC at the flywheel. Been at it for a while.
Cheers, Rob.
Offline clipperjay
Re: Timing belt concerns....Digifant
« Reply #1 on: 02 June 2012, 18:36 »
Have tried unscrewing the green plug or just pulling at it  :grin:
If you have TDC with the rod it should be TDC but guess the flywheel marker will help with timing strobe.
Offline oakgreener
« Reply #2 on: 02 June 2012, 19:00 »
I had the same problem with the green plug on mine. I had to run a junior hacksaw blade down the hole in a few places and carefully tap it out of the threads with a screwdriver. Trying not to let too many bits drop into the hole.
I then got another green plug and had to run the hacksaw blade around the threads to get it into the hole. It only screws in about 2 threads now. Good luck.
Offline Mr Blue
« Reply #3 on: 02 June 2012, 20:34 »
Sounds fine. Good thing about these is that even if the timing is off / timing belt snaps. They are fine  :smiley:
The green plug comes out with a small chizzel and hammer. Hammer it anti clockwise obviously.
Offline Loynes
« Reply #4 on: 03 June 2012, 10:10 »
When you smash the green plug out,  a spot of white paint (in my case harvest moon) on the timing groove helps the timing strobe a lot.  The garage who timed mine did it from one if the balance lugs on the fly wheel, told me it need injectors to explain the poor running !!!!!!!
Offline DG370
« Reply #5 on: 03 June 2012, 16:19 »
Not to tell you how to suck eggs but... Make sure you use the correct timing mark, theres a big notch in the flywheel and a smaller notch about 6mm to the left, it is this small notch you need to use
