Author Topic: tyre monitor system  (Read 3994 times)
Offline matping
  • MK1 20vT MK5 GTI T
tyre monitor system
« on: 02 June 2012, 17:36 »
can anyone give me a quick understanding on how it works? i press the button next to the ESP but doesent do anything  just flashes once on the speedo display
Offline VW Russ
Re: tyre monitor system
« Reply #1 on: 02 June 2012, 19:38 »
Hold it down for about 5 seconds I think it is
Mk5 GTI 08 in black, DSG, 18" monzas with a Zenec satnav thrown in for good measure.
Offline AlanD
  • MK5 2.0T 16v
« Reply #2 on: 02 June 2012, 22:06 »
From my limited knowledge on this you hold it down once you have inflated your tires to the PSI you want (32 PSI I think it is). It will then use the current pressure as a baseline and will alert you if it drops below the set pressure.
Offline Snooze
« Reply #3 on: 02 June 2012, 22:14 »
2.4 bar or 35 psi
2015 Mk7 Golf Gti 3dr Manual, Carbon Steel Grey, Michelin PS4's
Offline matping
« Reply #4 on: 02 June 2012, 22:41 »
brill thank you ill give this a go tomorrow
Offline Hurdy
« Reply #5 on: 03 June 2012, 12:51 »
You also need to be stationary when setting it. :smiley:
Seat Leon Cupra Black 290 DSG
Offline dubber36
« Reply #6 on: 12 June 2012, 12:19 »
It works using the wheel speed (abs) sensors. If a tyre deflates, its overall diameter reduces, therefore increasing the wheel's rotational speed and triggering the sensor.
On occasion, the sytem can be fooled if you go over a bump, a wheel leaves the ground, or you get a bit of wheelspin, but it happens too quickly for the ESP to step in and tell the TPS that it has the situation in hand.
Offline crimsonfin
« Reply #7 on: 12 June 2012, 12:52 »
Dont think this is the case.  Mine triggered last night when PSI had dropped to 21PSI from 35 PSI (probably got a a slow puncture  :cry:).  Thats a 60% drop before warning lamp alert on dash triggered.
Offline kalpsn2000
« Reply #8 on: 13 June 2012, 00:25 »
It works as per the description from dubber36 and thats why it needs to drop significantly before the alert comes up.
New: White Mk7.5 GTI (Standard...for now :smiley:)
Gone but not forgotten:
Diamond Black 2007 (56) Golf GTI 3Dr DSG ¦ 18" Monza II's ¦ Cruise control ¦ MFSW with Paddles ¦ Highline ¦ Rear parking sensors ¦ RCD500 to RNS510 C LED to Kenwood DNX521DAB ¦ Lowered on H&R springs ¦ R32 Rear bumper ¦ BCS Powervalve Sports R32 style TBE ¦ LED Rear Lights ¦ PDT Stage 1 ¦ NQSBBK ¦ 12mm Spacers ¦
Offline R32UK
« Reply #9 on: 15 June 2012, 15:54 »
to simplify... its pretty sh1t. check your tyres every week or so  :grin:
