Author Topic: 1st gear problem  (Read 1797 times)
Offline rudeone
1st gear problem
« on: 02 June 2012, 15:34 »
hello ,parked up wednesday all good then thursday having problems trying to get into 1st gear,it just does'nt want to go,goes into every other gear problem free but just won't go up into 1st,if i keep trying it does go in eventully any ideas/suggestions,apart from don't use 1st gear lol(91" gti 8valve if it makes a difference) ,thanks
Offline Loynes
Re: 1st gear problem
« Reply #1 on: 02 June 2012, 18:16 »
Mine did a similar thing, it was the gear linkage connectors they are white and they clip over the balls on the rods.  Mine started with 5th gear and just went completely I just reclipped it back in. Have a look might be that
Offline DG370
« Reply #2 on: 03 June 2012, 16:26 »
You can get replacement linkage rods from euro car parts or GSF for peanuts if there is play in them, you can also adjust the shift via a 13mm pinch bolt next to the downpipe
Offline JC
  • Back in the North.
« Reply #3 on: 03 June 2012, 18:45 »
make yasen a brew
get comfy
do a search for gear linkages
Offline rudeone
« Reply #4 on: 17 June 2012, 19:13 »
thanks for the advice ,i've just replaced the gear linkage rubbers and i've got 1st gear back  :smiley:
