Author Topic: Mk2 ABF owners  (Read 2019 times)
Offline tech1889
  • Mk2 GTI FTW !!
Mk2 ABF owners
« on: 02 June 2012, 14:23 »
I seem to have a problem.. Ive fitted my ABF into the mk2 but there seems to be clearance issue with the power steering pulley has anyone else had this ?? Will go get a pic and show how close it is in a min..
Also my power steering reserviour is fouling my o2a box any ideas ? just move it along chassis leg a bit more ?
Offline Franek
Re: Mk2 ABF owners
« Reply #1 on: 02 June 2012, 14:54 »
take off the thing that is between reservoir and chassis, and shorten it as much as u can to have it closer to chassis, but not too much so u can pyt your screws in it
Offline tech1889
  • Mk2 GTI FTW !!
Re: Mk2 ABF owners
« Reply #2 on: 02 June 2012, 15:12 »
Ok will have a look at doing that cheers
Offline tech1889
  • Mk2 GTI FTW !!
Re: Mk2 ABF owners
« Reply #3 on: 02 June 2012, 16:44 »
Here you can see how tight the room is
Offline oakgreengolf
  • CAR FOR SALE PM FOR FURTHER INFO
Re: Mk2 ABF owners
« Reply #4 on: 03 June 2012, 07:57 »
Mine is also very tight and I'm using a Toledo subframe and front crossmember. You could try lowering the front mount, this should give you more clearance if its catching on the top of the pulley.
Offline andyholli
Re: Mk2 ABF owners
« Reply #5 on: 03 June 2012, 08:40 »
Or you could swap to the other alternator mount with the tensioner spring underneath, so no extra pulley.
