Author Topic: Corrado Boot Spoiler  (Read 1932 times)
Offline dubstar9
  • Back to the Golf scene
« on: 01 June 2012, 20:23 »
Should I fit a Corrado boot spoiler to the Cabrio and if so, which of the following methods?
http://youtu.be/cCiO_JxV0LA
http://youtu.be/iaTvlI4W3bs
Offline murraymint
Re: Corrado Boot Spoiler
« Reply #1 on: 01 June 2012, 22:45 »
i like the one in the second video, looks like a lot of work tho
josh
« Reply #2 on: 02 June 2012, 00:00 »
What would be the point, not going to be easy.
Offline mark-mk3gti
« Reply #3 on: 02 June 2012, 00:15 »
Nice, prefer second slightly. Make it happen :)
Offline dubstar9
« Reply #4 on: 02 June 2012, 08:55 »
Well, like everyone on here who want to do something different to there Mk3 but without upsetting the lines of the car, the second video would be my choice. At stand still and up to 45mph the cabrio will look standard (making the cut run right across the bootlid from top of each rear lamp) and yes it would cost a bit to do but I already have the dash override switch and the relay (motors are cheap enough on flea bay).
When to look at the cost of fitting Audi door handles (£400 just for the kit from Venom), TT fuel caps, deleting wing repeaters and flushing bumpers it wouldn't look that costly to be different without spoiling the lines of the cabrio. Just my thoughts, others may see it differently, but if we all modified Golf's the same what would be the point of this forum :wink:
Funny last week I placed a bid on a motor complete with spoiler and was out when it finished, missed as I just bid £15 and it went for £16!!!
I got the switch for £4.99 and the relay for £9.99, bootlids go for between £25 & £70 for a Mk4 so parts wise I should get all I need for £100.
Mk3 or Mk4 bootlid??? :undecided:
Offline sharki786
  • GOT BOOST??
« Reply #5 on: 02 June 2012, 17:09 »
i love the 1st vid. i say DO IT. will look unique!!!  :cool:
*****MK3 Anniversary*****
*****MK4 GTI T*****
Offline Shady Pioneer
  • graphic designer.
« Reply #6 on: 02 June 2012, 18:03 »
Wouldn't say I love it but the first one is better than the second one. Go for it, be different. Do what you want with your car mate. :)
Offline stainesy
« Reply #7 on: 02 June 2012, 18:55 »
the first one looks like it has been made better than the seconds. but if you can do the second one and make it work perfect and line up spot on then defo the second one  :cool:
Offline dubstar9
« Reply #8 on: 02 June 2012, 22:40 »
I think if the second ones bottom cut was straight across the bootlid along the same line so the whole of the top lifted upit would look better and align better once in the down position. I don't like the two vertical cuts 2" in from the edges of the bootlid, where as one straight across would be less messy, just my thoughts :wink:
