Author Topic: Not happy  (Read 7220 times)
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: Not happy
« Reply #20 on: 02 June 2012, 10:53 »
back to where you got it mapped lol
I wouldn't be happy at all with that, it shouldn't be down to you to check over the car AFTER a map, they should really have felt something wasn't right if they took it for a test run (which they didn't by the sound of it)
Offline RTechUK
  • R-TECH OFFICE 01455 617233
Re: Not happy
« Reply #21 on: 02 June 2012, 11:22 »
could do with a full diagnostic check (preferably on a standard map) instead of a quick power run but from the limited logging info i did get, load requests being met without loading up the n75 duty cycle, negligible timing correction and close enough maf logs.. i would expect more from a stage 2 agu/k03s combo.
Maybe just a stage1 map on there then?  You still got your MPPS tool I can fire over a file to test which I know should give over 200bhp with ease on a k03s AGU, you will be fine over writing the Revo map its just the Me7 which can be iffy.
 01455 617233
Offline inggti
Re: Not happy
« Reply #22 on: 02 June 2012, 11:49 »
Nick Wots the waiting list for ur place and a rough ptice
Offline cullygti
Re: Not happy
« Reply #23 on: 02 June 2012, 12:02 »
how they telling you figures if they aint got a rolling road are they using logs to work it out  :undecided:
Offline cullygti
Re: Not happy
« Reply #25 on: 02 June 2012, 12:50 »
 :grin:  :grin:
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: Not happy
« Reply #26 on: 02 June 2012, 12:58 »
 :grin: :grin:
Offline harlemex
Re: Not happy
« Reply #27 on: 02 June 2012, 13:11 »
 :grin: :grin:
Offline topher
  • Administrator
  • fully functioning
Re: Not happy
« Reply #28 on: 02 June 2012, 13:31 »
I did consider it, but without the ability to read a backup to put back on afterwards, it could leave the customer in an awkward position regarding a refund or tweaks from the place he had it mapped. I've no doubt that a full diagnostic session would highlight some weak components.. most 1.8Ts seem to suffer that :grin: but imo first step is back to the place it was done.
Offline inggti
Re: Not happy
« Reply #29 on: 02 June 2012, 15:42 »
Well I'm bak there Wednesday. So willb in touch with u topher to book in for a full diagnostics
