Author Topic: mk4 brakes  (Read 3220 times)
Offline F17BAD
  • Golf MTM S3 GTI TURBO
Re: mk4 brakes
« Reply #10 on: 01 June 2012, 20:36 »
I dont know my mk2s but it should be ok if the calipers are the same? you only need the mk3 calipers so you can keep the old brake lines as the mk4 caliper lines are different. Brad had some custom lines made up so he could fit the whole lot maybe ask him where he got them from
I know i need conversion hoses for the back to fit the mk4 calipers, but thing is, i'm renewing all the brake lines too so maybe I can put mk4 stuff on the end of them and just use mk4 hoses, we will see I guess..
You will need differrent hoses for front too, they will connect to your MK2 solid lines fine mate, its only the Csaliper side thats different to the Mk2/Mk3
i just got the full set with connections that fit the MK4 rear callipers and S3 front callipers
You will need a 7mm spacer for front to fit the 312 carriers, the 312 callipers are same as the late mk3 288 items and on the rear you need to use the Mk3 Carriers (not sure if they are same as mk2) and the MK4 calipers fit this way.. you cannot use the mk4 rear carriers
pad wise, rear, Mk3 GTI ones fit
front just get them for mk4 GTI with 312 brakes
hope this helps a little
Not no ordinary GTI....
www.mixcloud.com/kells/
Re: mk4 brakes
« Reply #11 on: 02 June 2012, 00:08 »
16" wheels will fit over 312mm brakes fine.
Offline F17BAD
Re: mk4 brakes
« Reply #12 on: 02 June 2012, 00:19 »
Easily do, mine are 16" and theirs space left over, some rims however can be close, sometimes catching the stick on weights
Offline Dave_IOW
Re: mk4 brakes
« Reply #13 on: 02 June 2012, 13:02 »
Cheers Brad
So mk4 rears on mk3 carriers
mk4 carriers front, with mk4 calipers
Where did you get your hoses from?
Project: Mk2 20vT trackslag
Daily: Mk2 GTI typ19
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
Re: mk4 brakes
« Reply #14 on: 03 June 2012, 00:05 »
mk3 288mm calipers on mk4 312mm carriers upfront. Standard brake hoses utilised then. Just a 6mm spacer required to offset the carrier brackets correctly.
Offline Dave_IOW
Re: mk4 brakes
« Reply #15 on: 03 June 2012, 00:55 »
I haven't got the mk3 calipers, this is the thing... So will be putting my 288mm setup from the mk4 on to the mk3 setup then onto a mk2   :smiley:
Offline F17BAD
Re: mk4 brakes
« Reply #16 on: 03 June 2012, 10:50 »
Cheers Brad
Rear: Mk4 Calipers with MK3 carriers YES
Front: MK4 Carriers with either MK4 calipers, MK1 S3, TT, Octavia Vrs ETC..(these will all need new hoses) you can use MK3 288mm callipers and as thai-wronghouse says this way u can use the mk3 hoses.
I got HEL to make up my hoses
This page shows me fitting my front set up and shows the spacer. hoses etc
http://www.golfgtiforum.co.uk/index.php?topic=79957.2410
this page shows my rear callipers and hoses
http://www.golfgtiforum.co.uk/index.php?topic=79957.2460
