Author Topic: New coilovers issues  (Read 2056 times)
Offline Jimmyrallye
  • 20vt goodness
« on: 01 June 2012, 16:42 »
Bought a brand new set of jom coilovers everything went on fine but on passenger side im getting alot of postive camber which is munching my tyre on the arch :( ... Ive got a brand new set of wishbones going on over weekend anything else that can cause this ? Worn top mounts ? Thanks again guys for all your help
Heres a pic does realy stick out at the top
Offline Gti_Jamo
  • 1991 Corrado 1.8 G60
Re: New coilovers issues
« Reply #1 on: 01 June 2012, 17:43 »
The camber is adjustable in the two bolts that hold the coilover to the hub....if its the same as a Mk3 anyway which I assume it is.
Offline Jimmyrallye
  • 20vt goodness
« Reply #2 on: 01 June 2012, 18:19 »
Yes there are mk2/mk3 coilovers thanks alot il give that a try
Offline Mr Blue
« Reply #3 on: 01 June 2012, 18:31 »
Ok now is the best time to fit all new bushes. Wishbones, track rod ends and ball joints etc.
Adjust the ride height till you are happy then get a lazer 4 wheel alignment checked/adjusted. They will adjust the camber.
Prices vary from £30 - £100.
You ALWAYS need this checked/adjusted when you remove the front suspension.
« Last Edit: 01 June 2012, 18:33 by Mr Blue »
Offline Jimmyrallye
  • 20vt goodness
« Reply #4 on: 01 June 2012, 18:34 »
Its not the tracking its the camber on passenger side thats way out :( could some one confirm jom coilovers have camber adjusters on them
Offline Mr Blue
« Reply #5 on: 01 June 2012, 18:43 »
Almost all new suspension gives this issue. Once you fit the new wishbones and bushes etc. Take it to a specialist alignment centre and they will correct this camber for you. You can losen the top 17mm suspension bolt and push in the top of the hub so it sits straight and tighten the bolt again.
Chances are the tracking is also now out.
Fit the new stuff and have the camber and tracking adjusted. Will cost you less in the long run :smiley:
« Last Edit: 01 June 2012, 18:45 by Mr Blue »
Offline Jimmyrallye
  • 20vt goodness
« Reply #6 on: 01 June 2012, 18:49 »
Good stuff Mr blue will fit wishbones in mornind and get it all tracked up ... Thanks for that very helpfull :)
