Author Topic: wishbones track rod ends  (Read 2247 times)
Offline rolty_gti
« on: 01 June 2012, 12:24 »
hi guys,
i need to replace the wishbone and track rod end ball joint on the offside of my gti as there knackered and causing a knocking noise.
is it worth replacing the nearside ones at the same time too?
anybody have any links where you can pick them up as a set maybe?
cheers guys  :smiley:
LCR Decor - Quality affordable home improvements, we also take on commercial work, www.lcr-decor.co.uk free quotes! essex/london/kent and surrounding areas. call lee-07984106950 e-mail-leerolt@lcr-decor.co.uk
Offline rolty_gti
Re: wishbones track rod ends
« Reply #1 on: 01 June 2012, 12:30 »
also just remembered a car dealer friend of mine told me the other day that he has a mk4 golf gti 2.0l in his yard, would the wishbones and track rod ends be the same? i take it they would?
Offline jamie1989
« Reply #2 on: 01 June 2012, 12:36 »
yeah mate they should be fine to fit on yours,
If I do either side I always replace the opposite site the same time tbh.
1.6-1.8t AGU K03s, Forge actuator, Forge 007p, turbo back exhuast, Ths front mount, Catch can, 5 piece silicone boost pipes and creation sports tip. Stage 2 atm 232bhp 270lbs. Waiting for custom mapping :-)
Offline rolty_gti
« Reply #3 on: 01 June 2012, 12:43 »
yep that's same way i think aswell, but i dunno if it'd be worth taking them from both sides from the 2l gti he has or getting new ones?
suppose its just worth a look over there to see what condition there in and how much he wants for em!
Offline km
« Reply #4 on: 01 June 2012, 13:11 »
i'd just buy new ones, as they're quite cheap anyway, i get mine from motor factors!
Offline JimBR
« Reply #5 on: 01 June 2012, 13:45 »
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #6 on: 01 June 2012, 13:50 »
why do you need new wishbones? Buy new track rod ends, as said above it's not worth using second hand ones. The track rod ends are completely separate from the wishbones so the rattling may not be related
I'd also replace in pairs  :smiley:
Offline rolty_gti
« Reply #7 on: 01 June 2012, 14:25 »
technically i don't need new wishbones but they offside rear bush in the wishbone is knackered.because it looks like both wishbones have never been replaced i'd thought i'd replace them as when you buy them new they come wish all new bushes already installed which is less aggro and its just for piece of mind i know there brand new.
as for the offside track rod end ball joint, its also worn and needs replacing.
both were advisory items on my mot so i'm going to replace everything for piece of mind.
turns out the knocking noise has now dissapeared so far since i've installed some new spigot rings on the front of the car?
must've been knocking on something but didn't show any signs of wear anywhere.
the car dealer i mentioned i know pretty well and he said if i take my car up on tuesday i can swap over the wishbones and track rod ends from the 2l gti he has with mine free of charge as he is breaking the car.
so stuck between buying all new for piece of mind or getting it for free and solving it as a cheap fix? :undecided:
Offline Chris.
« Reply #8 on: 04 June 2012, 14:05 »
do all then 4wheel alignment.
Click For Build Thread
