Author Topic: Another Revo question  (Read 3291 times)
Offline GotaGTI
« on: 10 June 2005, 20:54 »
 :embarassed:
OK guys a dumb question from a new GTI owner  :wink:
Thinking of having a Revo remap done  :tongue:
But don't want to do much more, What else Is the minimum I need to do
ie Forge Dump valve, CAI, Exhaust etc  :undecided:
I don't want to bugger up the motor but what's the minimum I can get away with after an Revo  remap   :huh:
« Last Edit: 10 June 2005, 20:56 by GotaGTI »
Offline noobdubber
Re: Another Revo question
« Reply #1 on: 10 June 2005, 21:02 »
As far as I have gathered, you only need a forge dump valve, cos the VW wont last long with the extra power. You are better off getting a 4 bar fuel regulator aswell, you get an extra 15bhp for £50.
If you get the CAI, and the cat replacement exhaust, you can get an extra 10-15% more power. My revo dealer said if I get the stage 1, then get the exhaust and cai later, he'll upgrade for free
Offline GotaGTI
« Reply #2 on: 10 June 2005, 21:09 »
4 bar fuel regulator  :huh:
Could somebody please explain  :huh:
kingsmk2
« Reply #3 on: 10 June 2005, 21:16 »
increased fuel pressure means you can generally run higher boost thus meaning more ponies,,
Offline GotaGTI
« Reply #4 on: 10 June 2005, 21:18 »
OK but what is it exactly  :huh:
kingsmk2
« Reply #5 on: 10 June 2005, 21:23 »
fuel pressure is regulated by the fpr and what it does is ensure u maintain a constant pressure... by increasing the pressure the fuel flow into the cylinders will be greater and more of a mist improving the combustion... when running more fuel u can increase airflow and in turbo turms u can increase the boost pressure being fed into the cylinder aswell... so go get yourself an uprated fpr and and some big injectors and get that boost wound up!!
*please note its not quite as simple as it sounds,(before u go blowing things up!)
Offline GotaGTI
« Reply #6 on: 10 June 2005, 21:30 »
OK thanks guys, think I got It  :smiley:
200 bhp Is enough for me so Revo remap and Forge dump valve It is then  :tongue:
Offline GotaGTI
« Reply #7 on: 10 June 2005, 22:06 »
OK last question
What difference will It make to the MPG ?
Offline GazB
  • Newport Edition - aaahhhhh!AC Cobra Fast as F*@k -
« Reply #8 on: 11 June 2005, 19:05 »
OK last question
Makes none to mine
Offline GazB
« Reply #9 on: 11 June 2005, 19:05 »
Who's your revo dealer, cause if he'll put the satge 2 on for free, i'll pop and see him
