Author Topic: Spring compressors  (Read 4642 times)
Offline gashead1974
Spring compressors
« on: 31 May 2012, 18:30 »
I'm picking up a secondhand set of lowered/uprated shocks and spring to go on a mk3 gti this weekend, I've searched on here and other places but my question is...... as I'm replacing complete units ie dampers & springs (already assembled) will I need to use spring compressors either to get the old (complete) units of or to get the new ones on?
Many thanks
Gavv8
Re: Spring compressors
« Reply #1 on: 31 May 2012, 18:32 »
If your changing all the units complete you won't need spring compressors, but if you need to change the front springs then you will, you can change the rear springs without compressors.
Offline tweed
« Reply #2 on: 31 May 2012, 18:34 »
No.
You only need to undo the top mounts and undo the bolt and nut at the bottom.
Offline gashead1974
« Reply #3 on: 31 May 2012, 18:36 »
No.
Thats great news (as I dont own any compressors), thanks for the quick replies.
By the end of the weekend I should have the leather interior in and it dropped to sensible height,
thanks again :smiley:
Offline murraymint
« Reply #4 on: 31 May 2012, 18:37 »
No.
 :cool:
josh
Offline tweed
« Reply #5 on: 31 May 2012, 18:42 »
No you don't! You need to man the fcuk up and squeeze it down and turn the nut couple of times before you realise the spring  :wink:
Gavv8
« Reply #6 on: 31 May 2012, 18:54 »
I like my teeth where they are thanks..
Offline liva2704
« Reply #7 on: 31 May 2012, 20:57 »
Use compressors mate if you are changing the springs only mate,dont be stupid because believe me there is some serious power waiting and in all honesty if it hits you in the face it could actually KILL you.
Offline Dogbot
« Reply #8 on: 31 May 2012, 21:42 »
Paaah  lay it on the floor an stick the air gun on it.... I have the workshop record of shooting a shock leg six foot!! Audi a8 springs are under some fair old pressure!!  You can also use ratchet straps as ghetto spring compressors if you must x
Play careful kids it is dangerous pmsl
Offline tweed
« Reply #9 on: 31 May 2012, 22:36 »
You have obviously never undone one before. Springs don't fly off and bounce 10th high. It hardly moves at all. The spring length is about 15mm longer the the shock. How much force do you think the spring creates from being compressed 15mm?
