Author Topic: air filter on a 1.6  (Read 4146 times)
Offline 16valver dan
  • 1.8 20v turbo MK4 Golf
air filter on a 1.6
« on: 31 May 2012, 17:12 »
so i have a top mounted filter on car but it cant be doing much use because the pipe goes half into engine bay (presumably to fit to the heat pipe off manifold before i removed it) now iv got some of them fog lights that go in bottom corner grills, after taking a bulb out it leaves a nice hole. so my question is will the engine run better if i get a custom pipe run from end of filter and use the fog grill bits to make a direct air feed?
il update the sig when i get a good photoshoot ;)
Offline CJA321
Re: air filter on a 1.6
« Reply #1 on: 31 May 2012, 17:23 »
No offence, but on a 1.6 its not worth it would make such little differance if any
Offline kempie
  • where would we be without duct tape?
« Reply #2 on: 31 May 2012, 17:24 »
i wouldnt mind a idea for this too just too try and keep running temps down
Offline murraymint
« Reply #3 on: 31 May 2012, 17:25 »
I've got a closed gti type airbox with pipercross filter and cold air feed on my 1.6 but to be Honest it makes no difference
Edit: quick pic
« Last Edit: 31 May 2012, 17:27 by murraymint »
josh
« Reply #4 on: 31 May 2012, 17:30 »
but surely it will help with engine maintenance not having hot air throw through it all the time (live in a town stop starting all time engine heats up quickly)
Offline murraymint
« Reply #5 on: 31 May 2012, 17:32 »
Well yh I would stop hot air going in yh
josh
« Reply #6 on: 31 May 2012, 17:57 »
and you engine cover :O i want one
Offline murraymint
« Reply #7 on: 31 May 2012, 18:01 »
http://www.ebay.co.uk/itm/VW-POLO-MK4-1-4L-ENGINE-TOP-COVER-/170769945719?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item27c2ae9477#ht_500wt_689
It's a 6n polo 1.4 engine cover, I just sanded off the 1.4 badge, removed the vw badge and resprayed it. It's not a straight fit tho.
josh
Offline murraymint
« Reply #8 on: 31 May 2012, 18:01 »
Will look better on your engine too as you have the top mounted airbox like the polo
josh
« Reply #9 on: 31 May 2012, 18:12 »
ordered :)
