Author Topic: vacuum question  (Read 849 times)
Offline rio_gti
vacuum question
« on: 31 May 2012, 17:07 »
i had a thought......
i replaced all the vacuum pipes with silicone ones, but what would happen if they collapsed under vacuum?? what would be the symptoms??
was just a thought as when i temporeraly installed the boost gauge i used some old hose i found (for the fish tank bubblator  :grin: ) and the other day it wasnt working and i found the hose was flat  :embarassed:  so was thinking what could be happening if the other hoses were to flatten under vacuum, as its easy to sqweeze between finger and thumb
Re: vacuum question
« Reply #1 on: 01 June 2012, 00:12 »
Silicone hoses should not cause a problem, when ever I have fitted a boost gauge I always use silicone hose instead of plastic.
Offline rio_gti
Re: vacuum question
« Reply #2 on: 01 June 2012, 10:22 »
just wanted to know what the symptoms would be if the hoses collapsed ie no vacuum going thru the pipes  :undecided:
