Author Topic: driving issue  (Read 1376 times)
Offline Ray_Ray280
driving issue
« on: 31 May 2012, 15:27 »
Hello,
I have a 1.8 N/A gti and it seems to be a bit juddery whilst driving example i will be pulling out of my street not quick but the car with take its time to give me the power and when it does it will be juddery
i no on a astra i once had the EGR valve had to be blanked off is this the case with a golf or not?
Thanks
Ray
Offline Ant1981
  • Feed me, prod me
Re: driving issue
« Reply #1 on: 31 May 2012, 16:43 »
Clean the EGR out rather than blank it off.
'09 Kawasaki Ninja ZX-6R
Offline Ray_Ray280
Re: driving issue
« Reply #2 on: 31 May 2012, 17:24 »
where is the EGR located ?
Offline richw911
Re: driving issue
« Reply #3 on: 31 May 2012, 17:38 »
Do a throttle body clean - any fault codes?
Offline Ray_Ray280
Re: driving issue
« Reply #4 on: 31 May 2012, 17:42 »
im awaiting a cable from ebay then i will do a fault test  i will clean the throttle body at the same time at the egr valve
Offline Ray_Ray280
Re: driving issue
« Reply #5 on: 01 June 2012, 13:30 »
well i cleaned out my tb today ans there was oil in there not a lot prob about 1/2 a teaspoon is this normal?
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: driving issue
« Reply #6 on: 01 June 2012, 16:08 »
they get gummed up due to the breather design putting oily vapour back into the inlet so it wouldn't have helped being like that. Best off waiting for the fault code reader before you do anything else in case you're wasting your time
Offline Ray_Ray280
Re: driving issue
« Reply #7 on: 06 June 2012, 00:45 »
update on this:
had a spirited drive today and it feels like the car isnt powering correctly it will rev up fine but will hold back on the power then give you some then will take it all away whilst the revs are still rising im thinking either a MAF or the EGR valve im still waiting for the lead to turn up to scan it tho unless someone in the cornwall area has the leas and software to lend me
