Author Topic: 4bar fuel pressure regulator?  (Read 2583 times)
Offline noobdubber
« on: 10 June 2005, 19:02 »
I just had the 5hr revo trial. The bloke said that its a 53plate, so it might have the 4 bar already installed, so It'll be a 224 trial and not a 212. Is there any way of finding out if it has one ot not?
Its a big difference, even from the 180bhp standard :grin:
Offline GazB
  • Newport Edition - aaahhhhh!AC Cobra Fast as F*@k -
Re: 4bar fuel pressure regulator?
« Reply #1 on: 10 June 2005, 20:43 »
look on your FPR it is marked on it, 3 or 4 bar.
Don't think you will have a 4 bar tho because if you check out revo's website the claim that the 150 and 180 produce the same final figure
« Last Edit: 10 June 2005, 20:48 by gaz8512 »
Offline GazB
« Reply #2 on: 10 June 2005, 20:50 »
Offline noobdubber
« Reply #3 on: 10 June 2005, 20:57 »
Its only a 3 bar!!!
bad in a sense, gonna cost an extra £50
Means I'm gonna get another 17 ponies out of it now though :grin:
Offline GazB
« Reply #4 on: 10 June 2005, 21:23 »
You can get em cheaper than £50,  I would'nt count on getting that much more power tho,  When mine had just revo and 4 bar, it only made 212 on the rollers.  Let us know how you get on
kingsmk2
« Reply #5 on: 10 June 2005, 21:29 »
get an adjustable one and then save up for some bigger injectors... then u should be able to gain more boost..
Offline noobdubber
« Reply #6 on: 10 June 2005, 21:59 »
where can you get them cheaper than £50?
Offline GazB
« Reply #7 on: 11 June 2005, 18:34 »
http://www.westecperformance.co.uk/  £41 inc Vat
Offline Grantos - Westec
« Reply #8 on: 11 June 2005, 22:16 »
Thanks for the plug Gaz!
Get yourself a bigger diameter MAF housing and a 4bar reg.
As I recall there are no 1.8T engines that come with a 4bar.
Offline GazB
« Reply #9 on: 11 June 2005, 23:02 »
Whats this bigger diameter maf all about grant :undecided: sounds interesting
