Author Topic: Removing front silencer  (Read 1679 times)
Offline P2Daz
« on: 10 June 2005, 17:50 »
The front silencer on my mk2 8v has shot it,i was wondering if anyone else has just replaced it with a straight through pipe?
I would expect an increase in noise but how much?
« Last Edit: 10 June 2005, 19:15 by t5chav »
Offline ...joe
Re: Removing front silencer
« Reply #1 on: 10 June 2005, 18:07 »
not a great deal noisier, you may as well go for it. you may have to space up/down either end of the pipes to fit the new centre section
mail@trimdeluxe.co.uk
www.facebook.com/Trimdeluxe
Offline BobbyT
« Reply #2 on: 10 June 2005, 18:32 »
removed the middle box when i had a mk4 astra and it sounded like it had 300bhp shame it only had 115!! had a sports rear box mind! cheap mod!  :smiley:
Offline P2Daz
« Reply #3 on: 10 June 2005, 19:17 »
How do you mean space/up down? do you mean getting an over or under size diameter pipe? Does anyone know what size i should be looking for?
cheers
Offline Mr Blue
« Reply #4 on: 10 June 2005, 19:49 »
mine is replaced with a straight system (full stainless front to back) and it sounds like a spit fire plane when idle. Lost alot of back pressure too.
stick to standard if you want it silent imo
Offline ...joe
« Reply #5 on: 10 June 2005, 23:59 »
cheers
yeah most straight through pipes are part of systems, or to go with performance systems so they tend to be a larger bore, i.e your exhaust is around 1.5" bore, my system is over 2.5" so you'd have to pack out an inch.
