Author Topic: Off set?  (Read 1310 times)
Offline johnomk4
Off set?
« on: 30 May 2012, 17:45 »
Will et35 stick out more than et33 or is it the other way around?
As I have et33's on my car now and they rub every so often, so wanted to know if et35's will sit further in?
Offline jamie1989
Re: Off set?
« Reply #1 on: 30 May 2012, 17:47 »
What tyres have you got on your alloys now?
For example if you have 225/40's then drop to 215/40 or even 215/35.
This will reduce scrubbing and cheaper than buying new wheels  :smiley:
1.6-1.8t AGU K03s, Forge actuator, Forge 007p, turbo back exhuast, Ths front mount, Catch can, 5 piece silicone boost pipes and creation sports tip. Stage 2 atm 232bhp 270lbs. Waiting for custom mapping :-)
Offline johnomk4
Re: Off set?
« Reply #2 on: 30 May 2012, 17:55 »
Yea I'm running 225/40 at the mo, but had these other wheels at a price I could not refuse, and they look alot better than what I have on at the mo.
So I take it they will stick out more then?
Offline johnomk4
Re: Off set?
« Reply #3 on: 30 May 2012, 20:41 »
Anybody?
Offline scarr89
  • Mk4 Golf, DERV FTW!
Re: Off set?
« Reply #4 on: 30 May 2012, 20:46 »
The less ET the more it sticks out. So 33 will stick out more than 35. I don't know exactly how many mm's '1 ET' is so don't ask   :rolleyes: :tongue:
Offline johnomk4
Re: Off set?
« Reply #5 on: 30 May 2012, 20:51 »
Sorted I thought it was something like that but wasn't quite sure. Thanks.
 :smiley:
Offline Rhyso
Re: Off set?
« Reply #6 on: 30 May 2012, 21:03 »
Lower the number = MORE POKE
e.g my Monty 2's were ET42.  Anni's were ET38
Offline dom
  • Back in a Mk4
Re: Off set?
« Reply #7 on: 30 May 2012, 21:55 »
Anybody?
They will sit 2mm further in :wink:
Offline JimBR
Re: Off set?
« Reply #8 on: 30 May 2012, 22:11 »
Yeah it's 1mm per ET
Offline johnomk4
Re: Off set?
« Reply #9 on: 30 May 2012, 22:18 »
Good good that means I can keep my rubber and have no rubbing issues now.
Do I take it then that if I wanted to put spacers on then I will have to put stretched tyres on??
 :smiley: :smiley:
