Author Topic: Mk3 VR6 ECU...  (Read 2793 times)
Offline MattJAbela
Mk3 VR6 ECU...
« on: 30 May 2012, 11:48 »
Sorry about all the random questions guys, its the first engine conversion im doing and i want to get it right..
Basically, when getting the interior out of the vr6 last night, we found an ECU looking type thing under the rear bench, just wondering if this is in fact the ECU or something else?? Just i've never seen an ECU in this position?
Thanks
Offline tshirt2k
  • Been there...Done that...
Re: Mk3 VR6 ECU...
« Reply #1 on: 30 May 2012, 11:49 »
Its not an engine ECU
Mk3 ABF 16VT Megasquirt V3
Offline MattJAbela
Re: Mk3 VR6 ECU...
« Reply #2 on: 30 May 2012, 12:14 »
Any idea what it is for??
Offline tshirt2k
Re: Mk3 VR6 ECU...
« Reply #3 on: 30 May 2012, 12:18 »
Picture or part number? Never come across an ecu under there.
Offline MattJAbela
Re: Mk3 VR6 ECU...
« Reply #4 on: 30 May 2012, 12:25 »
Will get one later..the cars an auto if that helps?
Offline tshirt2k
Re: Mk3 VR6 ECU...
« Reply #5 on: 30 May 2012, 13:08 »
You sure its not an amp?  :undecided:
Re: Mk3 VR6 ECU...
« Reply #6 on: 30 May 2012, 13:29 »
I would guess it is something aftermarket.
Offline MattJAbela
Re: Mk3 VR6 ECU...
« Reply #7 on: 30 May 2012, 13:43 »
It looks really very standard, the cables wrapped in the same fabric stuff that the normal cables are wrapped in. Looks like the standard cable colours. Sure it had a VW part number on it too. Im going over there at 5 today to carry on. Its really confusing. Its not an AMP, i will get a part number later for it and see if that helps?
I googled Volkswagen VR6 auto gearbox ECU and a few things came up that look the same. Does the gearbox have an ECU??
Offline tshirt2k
Re: Mk3 VR6 ECU...
« Reply #8 on: 30 May 2012, 13:51 »
Yea they usually do.
Offline MattJAbela
Re: Mk3 VR6 ECU...
« Reply #9 on: 30 May 2012, 14:29 »
Im guessing its that then?? If i call up VW with the parts code on it will they tell me what it is?
