Author Topic: Spacers, bolt through or bolt to hub first?  (Read 1463 times)
Offline Bellend
« on: 29 May 2012, 22:40 »
What do you think is better? The ones with real long bolts that go through the wheel then the spacer and into the hub or ones that bolt to the hub then the wheel bolts to the hub.
Where all my moneys went.
Offline Khare
  • The bear that khares
Re: Spacers, bolt through or bolt to hub first?
« Reply #1 on: 29 May 2012, 22:41 »
So long as they're hubcentric then no difference.
Although the ones that bolt to the hub then the wheel bolts to them probably make it easier when it comes to sticking a wheel on/off.
Offline Bellend
« Reply #2 on: 29 May 2012, 22:53 »
OK cheers. Trying to sum up what's safer but I suppose as long as they are tight then it shouldn't make any difference as you say......
Offline Ess_Three
« Reply #3 on: 29 May 2012, 22:58 »
Long bolts only for me.
One less failure mode...also, longer bolts help even the tension on the bolts.
You can hold them onto the hub using a longer countersunk screw in place of the disc retaining screw.
On 13mm/16mm or above, you can drill a recess for a cap head screw, if required.
..but gaining motorcycles.
« Reply #4 on: 29 May 2012, 23:55 »
Given the choice, longer bolts would be what I would use.
Offline Bellend
« Reply #5 on: 30 May 2012, 00:12 »
Cheers, ordered some bolt through ones. :)
