Author Topic: Replacing my t t t t t. t t t t t tappets  (Read 2195 times)
Offline Organisys
  • Old and Slow...
« on: 10 June 2005, 13:54 »
Doing the tappet thing tommorow in my brothers workshop. (He is a motorcyle mechanic in south London. )Anybody have any helpfull advice/ tips things to look out for? Many Thanks... Would it be worth doing a photo shoot and how to for anyone?
Cheers.
Offline ...joe
Re: Replacing my t t t t t. t t t t t tappets
« Reply #1 on: 10 June 2005, 17:55 »
can't hurt to take some photos, its pretty straight forward, the only tip would be to unbolt the cam in stages so you don't put too much stress on it as they can crack. but thats common knowledeg for mechanics! go for it!
mail@trimdeluxe.co.uk
www.facebook.com/Trimdeluxe
Offline Organisys
  • Old and Slow...
« Reply #2 on: 11 June 2005, 17:06 »
Ok, so I got to my brother's workshop, (he shares workshop with car mechanic) car mechanic was working today (not usually on sat) and he took over! did the job in about 20 mins with interuptions!
no tick tick tappets any more...... however we seem to have upset something slightly as the idle hunts down, then jumps up again occasionaly.....ISV need cleaning? The timing is ok and all vacuum hoses seem fine as well.....?
Finished refurb and polish on the alloys today as well, here is a pic... getting tyres on monday...Eage F1's.
They are some old school ATS 5 spokes 15x7j et38, the logo part of the center caps were shot, hence the cheeky VW stickers.. lol.
« Last Edit: 11 June 2005, 17:16 by Organisys »
Offline knobby
« Reply #3 on: 12 June 2005, 00:17 »
what Mk2 u got?
Dave
Old VW's never die...they just go faster!
Offline Organisys
  • Old and Slow...
« Reply #4 on: 12 June 2005, 21:38 »
Its a 1990 Digifant 8v mate....
Offline knobby
« Reply #5 on: 12 June 2005, 21:48 »
and did the job look relatively easy to perform?
Dave
Offline Organisys
  • Old and Slow...
« Reply #6 on: 13 June 2005, 12:06 »
Yes, looked easy, make sure you are carefull about marking the timing, and undo the cam shaft bolts in the correct sequence, then use a torque wrench to re-torque them again. A usefull tip i guess is to remove the air box completely which he did, to make things more accessable. Oh and a good idea to get a new cam cover gasket.
Offline ...joe
« Reply #7 on: 13 June 2005, 20:07 »
i'd take your throttle body off and give that a good shot of brake cleaner, if you've had sh!tty oily stuff come throught the isv it may be stick ing the butterfly's and be constantly trying to correct its self., easy job, four 6mm allen head bolts. while your at it i'd clean your isv and check the condition of the crankcase breather and the bung that sits in the rocker cover as these are prone to splits which can also affect your idle.
Offline ...joe
« Reply #8 on: 13 June 2005, 20:07 »
wheels look sweet by the way! :wink:
Offline Organisys
  • Old and Slow...
« Reply #9 on: 13 June 2005, 22:15 »
Hmmm.. Thanks Joe. Will do when have time, temporarily fixed problem a little by increasing idle speed, whixh seems to have stopped the revs dropping off, and then hunting back up.
The throttle body did look quite clean, apart from some gunk from one of the breathers near the air inlet (forget which).
The rockercover bung looks fine, I did check that.
 :smiley:
