Author Topic: carbon canister delete  (Read 1732 times)
Offline GTIcheeseman
« on: 29 May 2012, 15:39 »
what are peoples thoughts on it?
Offline Dalo Harkin
Re: carbon canister delete
« Reply #1 on: 29 May 2012, 15:42 »
I wouldnt personally do it unless the pipes were corroding.
I did mine but only because the pipes were like mush, and I had a spare resistor lying around.
Does make the bay look a tad neater too.
« Reply #2 on: 29 May 2012, 16:02 »
Does it thro up any codes or problems? For a 2 quid resistor I don't see the harm you got any pics of what you connect the resistor too?
Offline Yohan
« Reply #3 on: 29 May 2012, 16:18 »
You connect the resistor across the plug you remove from the unit. Mine still threw a fault code though but R-Tech mapped the fault out for me  :smiley:
It does let you remove a load of vacuum tube from your system which is one less source of leaks.
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #4 on: 29 May 2012, 17:06 »
It won't do anything on an AGU but AUM/AUQ it may throw up a code even though the resistor is fitted
« Reply #5 on: 29 May 2012, 17:28 »
cool so you jsut conect it to both pins on the plug
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #6 on: 29 May 2012, 19:27 »
You got it
« Reply #7 on: 29 May 2012, 19:28 »
gonna give it ago as the reisitor is only like 2 quid
Offline Dalo Harkin
« Reply #8 on: 30 May 2012, 07:00 »
I have used the same resistors for the:
N249 and N112 delete
SAI removal
Carbon canister delete
So if you plan on doing any of these order more  :laugh:
Offline JimBR
« Reply #9 on: 30 May 2012, 08:34 »
I just left the n249/112 plugged in with no vacuum line connected to them. My SAI connector is just left unplugged.
No engine management light as of yet :)
If it comes on I'll get the codes mapped out. I don't buy the whole resistor thing.
