Golf mk2
Over revving valver
Topic: Over revving valver (Read 1522 times)
TIM20
GTI forum regular
Over revving valver
10 June 2005, 06:27 »
I have a problem with my valver
I had to change the rocker cover oil seal and since i have put it back together i have had the following problem
When i start the car after its been sat it revs at about 2000 rpm ( making me look like i cant drive)
Then once is been driven even a few hundfred meters it settles down to a nice steady 1000 rpm tick over.
Occasionally it runs at around 900rpm on tick over and sounds rough
Any ideas??
Cheers Tim
Slimmedmk2
Slammedmk2`s Back!
Re: Over revving valver
10 June 2005, 06:50 »
Have you checked all the connections are tight,especially on the isv?
Gambit
Forum addict
10 June 2005, 11:27 »
if you've had the rocker cover off then you've had to disconnect the throttle switch
check the throttle switch & its wiring, make sure none of the wires are broken and that the switch is closing when throttle is closed
Golf mk2
Over revving valver
