Author Topic: AGU 1.8t remap limits  (Read 2942 times)
Offline GTIcheeseman
« on: 28 May 2012, 21:54 »
i have been reading up about remapping an agu 1.8t with a k03 that it will only take 200bhp
im just wondering i have a few extra mods on mine so and i wanna get it remapped but i dont wanna replace the turbo yet as im saving up for other stuff but i got enough for a remap.
the mods i have so far are:
- superchips, chip
- j series n75
- G60 flywheel and VR6 clutch
- creation motorsport TIP
- creation motor sport throttle pipe#
- ths pancake pipe
- lightweight pulley kit
- turborevs SMIC
- 3 bar fpr
- 2.5 inch exhaust
- 3" down pipe and cat
- ITG foam filter
- R32 intake pipe upgrade
- new engine oil
- new gearbox oil
- k&n oil filter
- bailey recirc
- silicone breather pipes
- ECS cam belt kit
« Last Edit: 28 May 2012, 21:55 by GTIcheeseman »
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: AGU 1.8t remap limits
« Reply #1 on: 28 May 2012, 22:07 »
the turbo is the limiting factor on the AGU
Offline Toby
  • Car - less
« Reply #2 on: 28 May 2012, 22:17 »
Best bet is hold off, and buy a decent ko3s and bigger injectors, and a custom
Remap
And a fmic to get the best out of it!
Worth the money!
Currently down under
Offline dom
  • Back in a Mk4
« Reply #3 on: 28 May 2012, 22:35 »
This.
None of those supporting mods will extend the capabilities of the turbo. Without a bigger turbo you're going to be limited.
« Reply #4 on: 28 May 2012, 22:49 »
That calls a stop to that then
Offline Toby
  • Car - less
« Reply #5 on: 28 May 2012, 22:58 »
Just bolt a ko3s on n get it mapped, should see 225bhp if not more with 2.5" intercoller pipe work n fmic n injectors
« Reply #6 on: 29 May 2012, 08:45 »
Thanks for the help but like I said before I don't wanna be spending hundreds and hundreds and hundreds
Maybe if I could get the busted ,k03s rebuilt for cheap I'll keep it
« Last Edit: 29 May 2012, 10:10 by GTIcheeseman »
Offline Dalo Harkin
« Reply #7 on: 29 May 2012, 09:41 »
Dont mean to hijack the thread but why do you need different injectors on a K03S, I thought standard injectors were fine with a K03S? and you only needed injectors if you were going the K04 route
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #8 on: 29 May 2012, 17:05 »
Injectors are the next limiting factor on the AGU, standard are good for around 225bhp
Offline Chris.
« Reply #9 on: 29 May 2012, 20:09 »
On a GOOD set of injectors you will max out at 230-235bhp.
K03s with forge actuator and good FMIC and r-tech mapping is where its at.
If you want to push it a bit further, bigger injectors and VR6 maf housing.
Click For Build Thread
