Author Topic: Drop links  (Read 1376 times)
Offline scarr89
  • Mk4 Golf, DERV FTW!
Drop links
« on: 28 May 2012, 17:13 »
Should they be fitted with the arm 'hanging' freely or could you use a jack, raise it up to make it line up?
I have 1 adjustable fitted that lined up with not hassle, as it the arm was just hanging there with no weight on the axles. But unfortunately I lost the bush for the other adjustable one and washing thinking of re using my old original one. But I would need to raise the arm up a tad with a jack to make it line up...
Ok to run 1 OEM 1 adjustable for a while until I get some new adjustable drop links...
Ok if I switch back to both original drop links but have to raise up both of the arms to get the holes lined up...
Not ok to run one of each, get some new adjustable ASAP otherwise you will crash and die...
Please answer below  :smiley:
« Last Edit: 28 May 2012, 18:25 by scarr89 »
Offline JimBR
Re: Drop links
« Reply #1 on: 28 May 2012, 17:22 »
Yay
Offline scarr89
Re: Drop links
« Reply #2 on: 28 May 2012, 18:23 »
Yay
Did you just say that cause I asked yay or nay or actually understood the question and reckon I could use 1 original drop link by raising the arm up?  :tongue:
Offline JimBR
Re: Drop links
« Reply #3 on: 28 May 2012, 18:26 »
No I understand  :grin:
Put the jack under the wishbone and raise it until the bolt lines up then voila  :smiley:
Offline scarr89
Re: Drop links
« Reply #4 on: 29 May 2012, 16:48 »
100% fine to run with the plastic ones?  :rolleyes:
Offline JimBR
Re: Drop links
« Reply #5 on: 29 May 2012, 17:48 »
I'd change both sides to the plastic ones until the new ones come.
Offline scarr89
Re: Drop links
« Reply #6 on: 29 May 2012, 18:41 »
Could I just run the plastic ones forever/until they need replacing? Or are metals adjustable ones a must?
Offline JimBR
Re: Drop links
« Reply #7 on: 29 May 2012, 19:21 »
If running a standard ARB and have lowered it 40mm or less then yeah I cant see why not.
Offline scarr89
Re: Drop links
« Reply #8 on: 29 May 2012, 21:37 »
What about an eibach front ARB? :rolleyes:
Offline JimBR
Re: Drop links
« Reply #9 on: 29 May 2012, 23:49 »
Can't see why not. As long as the eibach is compatible with oem bolts and doesn't need ones with a different thread or whatever.
