Author Topic: New Aircon Pump!!! Part number needed ?  (Read 3479 times)
Offline Mike_MK4
« on: 28 May 2012, 13:42 »
Went to get my aircon re-gassed and the mechanic said he filled it up with no leaks but when he went to test it out, it was still blowing out warm air!
They've had it back again today and determined the pump/ compressor dead!  :sad:
he said a new one is £5-£600 from main dealer but he recommended buying one from Ebay and they'd fit it.
Does anyone know the part number I'd be looking for as I've seen a few but want to get it right one.
Thanks
Re: New Aircon Pump!!! Part number needed ?
« Reply #1 on: 28 May 2012, 13:45 »
A good air con specialist will be able to confirm where the system is leaking.
Might be better to do that than buy a pump you may not need.
Offline Mike_MK4
« Reply #2 on: 28 May 2012, 13:51 »
they used the dye to check for leaks and said that the system itself is still sealed but the compressor/ piston itself isnt opening up and working properly so a new pump is the way forward???
Offline Toby
  • Car - less
« Reply #3 on: 28 May 2012, 13:52 »
What's air con?  :grin: all about ze windows
Currently down under
Offline stfc_gti
« Reply #4 on: 28 May 2012, 13:54 »
this was the case in my old 306
2002 1.8T GTI AUM, Standard (not for much longer)
Offline Mike_MK4
« Reply #5 on: 28 May 2012, 14:04 »
anyone know the part number I'd need? Golf GTI MK4 2001 (115) 3 door..??
« Reply #6 on: 28 May 2012, 14:09 »
Well it is a risk buying a s/h one but I think they are the same as the 1.8 pump
Offline Kerrse
« Reply #7 on: 28 May 2012, 15:10 »
I have been trying to sort my aircon out on mine too as the mrs is going mental as its not working, tried regassing, new climate control about to change the air con pressure switch I am guessing if that doesnt work it will be the aircon pump next  :cry:
Offline Mike_MK4
« Reply #8 on: 28 May 2012, 15:19 »
i know...its a pain! Thankfully they've tracked it down the the compressor/ pump before i paid out for new controls, and pipes and what not.
Mechanic said there were no leaks and the switches were ok but its the pump itself is dead so I'll be praying it'll be ice cold by the end of the week...just in time for the next 2 weeks worth of rain!!  :cool:
Offline Kerrse
« Reply #9 on: 29 May 2012, 16:04 »
Well i have just replaced the a/c pressure switch & still no aircon  :cry: that was £51 down the drain. Taking it to my vw mechanic m8 to see if he can work it out maybe well be the aircon compressor/pump gets changed next
