Author Topic: Do I need to change Aum pipes to AGU  (Read 4183 times)
Offline oceanic-green
  • Mk4 1.8T Aum 260+ Bhp 273 TQ
« on: 27 May 2012, 09:29 »
Every time I think I have fixed the last boost leek I will have, within a couple of days I get another new one appearing :angry: The power must find the next weakest point to brake and escape from!
So, I want to fix what I HOPE is the last boost leak I need to fix, which is the Charge pipe and its stupid c clip connection to the hose that joins on to the pancake pipe. What I want to know is if I change the charge pipe to an AGU charge pipe, and get the samco outlet to pancake hose to fit on it, will I also need to replace the other three AUM silicone hoses that I have just put on to the other end of the charge pipe that go to the N75, the Diverter valve, and the turbo outlet, to AGU ones, or will the AUM ones still be ok to use on an AGU charge pipe?
Thanks
Mods: R-Tech custom remap, Beachbuggy K250 Turbo, Forge 007 DV, RAMAIR Jetstream 108 induction filter, silicone piping throughout, R-Tech Supersize TIP, 42 Draft Stealth Catch Can, N249 bypass, Ported Manifold, Toyo Sports FMIC with 2 & 1/2 pipes, Custom made full turbo back exhaust & 2 & 1/2 " downpipe and 200 cell sports cat. BAM injectors, Turbosmart Boost Gauge, BBS CK Wheels, 312mm Brembo front discs and pads, Carbon canister delete and last of all, a liquid cube!
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: Do I need to change Aum pipes to AGU
« Reply #1 on: 27 May 2012, 10:22 »
the AUM pipe with the C clips is the only one that has the problem I think
« Reply #2 on: 27 May 2012, 10:56 »
Sorry, I may not of been very clear in my question. Do you know if my creation motor sport AUM silicone hoses from my AUM charge pipe to the diverter valve, N75 and turbo outlet will also fit on a new AGU charge pipe, or will i need to get new AGU silicone pipes to fit the AGU charge pipe.
Thanks
Offline Scott D
« Reply #3 on: 27 May 2012, 11:07 »
AUM hoses will fit the AGU pipe, I found only the outlet to pancake pipe needed cutting down slightly to fit on to the charge pipe, other than that is a direct replacement for the AUM.
2003 1.8T GTI 180 - APR Stage I, S2000 Filter, R-Tech Supersize TIP, Bilstein B12 Suspension, 18" OZ Superleggera, Recaro Heated Leathers, US Spec Rear Lights, N249/SAI/PCV Delete
1.8T AUQ - 241bhp & 286 ft-lb
R-Tech Map, Forge FMIC, SFS Oversized TIP, Ported Manifold, Milltek Turboback non res exhaust, Forge 007p, N249 & N112 delete, SAI delete, S2000 Air Filter, Sachs clutch & Lightweight Flywheel
« Reply #4 on: 27 May 2012, 11:23 »
Great! thanks, I should have no trouble then  :laugh:
« Reply #5 on: 28 May 2012, 10:13 »
If I have understood you correctly, then I don't need to purchase the AGU outlet to pancake hose, as the AUM one will fit the AGU charge pipe if I cut it down a bit.
Is that right?
Thanks
Offline Scott D
« Reply #6 on: 28 May 2012, 11:35 »
the AGU hose needed to be cut down, AUM will not fit as different connections.
« Reply #7 on: 28 May 2012, 12:15 »
Ahh I see, thanks
