Author Topic: Joey'd lights  (Read 2890 times)
Offline 67buggers
Joey'd lights
« on: 26 May 2012, 21:03 »
Right as I'm now keeping my mk3 I've decided to get it finished.......I really want to joey the lights but I'm worried because last time I did a set I used what was described as soft masking tape to mask them up but when I peeled it off it took the chrome up with it in places....any body got any recommendation on what tape to use to prevent this? Also can some one please tell me what helper springs are on coil overs and what effect removing them has.  :smiley:
I fix iPhone's and iPod's, I can fix most faults call me on 07811344816 for a quote
Offline dom
  • Back in a Mk4
Re: Joey'd lights
« Reply #1 on: 26 May 2012, 21:48 »
I've joey'd a few sets of headlights and never masked them up, a ball of tissue and a steady hand is all that you need.
Helper springs are the small springs above the adjuster rings, removing them allows you to go lower.
Offline 67buggers
Re: Joey'd lights
« Reply #2 on: 26 May 2012, 22:01 »
Nice one....they'll be coming out then! Will tissue be ok? I have heard you use Vaseline but not tried it
Offline Screech16v
  • MK3 20vt AGU
Re: Joey'd lights
« Reply #3 on: 26 May 2012, 23:16 »
Vasaline and tissue ummm  :grin:
Offline search
Re: Joey'd lights
« Reply #4 on: 26 May 2012, 23:38 »
LULZ.
i'v not done it but will be attempting it soon. but did see a guy with mk4 style lights brushed paint on.  i cant do this as i have a blue car i expect black cars can do this as black is pretty much black lol.
maybe cut out some cardboard same size shape etc etc.
Golf mk3 1.4 (sold)
Golf mk2 1.3 (sold)
Golf mk3 1.6
Offline stainesy
Re: Joey'd lights
« Reply #5 on: 27 May 2012, 09:09 »
i did mine with a brush so no need to mask anything. just cut it in.
Offline liva2704
Re: Joey'd lights
« Reply #6 on: 27 May 2012, 09:12 »
Did mie with a brush also,easy enough if you take your time and hav'nt had a drink the night before :sick:
Offline Deano2711
  • 1992 VR6
Re: Joey'd lights
« Reply #7 on: 27 May 2012, 09:17 »
Kids paint brush and a can of paint is all you need. Takes a bit of time and a couple of coats but looks loads better when done  :wink:
Offline Dogbot
Re: Joey'd lights
« Reply #8 on: 27 May 2012, 10:10 »
if you get the tape, an you stick it to a clean surface a few times it will loose its tack, altenatively you could buy yourself some low tack lining tape from your local bodyshop stores likes of southern paint supplies or leonard brookes paints
that will not bleed like normal household masking tape and is designed for lining onto hardening fresh paint in the paint booth.
Im personally yet to see a set of joey'd lights brush painted that dont look gash close up no matter how many coats you put on, willing to be proven wrong tho guys please do tho maybe your craftmanship is better than the ones i have seen so far, however you can reduce the brush strokes in the paint a great deal by putting the can of paint in a pot of very hot water, this aids a smooth brush stroke, but for something like this you will need a longer brush hair & a good quality brush, its kinda like coach painting technique.
the choice is yours tho!!
Offline Junior74
Re: Joey'd lights
« Reply #9 on: 27 May 2012, 11:10 »
As said, paintbrush and tin of paint...
