The garage
Dump valve chatter
Topic: Dump valve chatter (Read 2886 times)
Lee_anni1619
Dump valve chatter
26 May 2012, 19:38 »
Hi, i recently purchesed a 007p dv for my mk4 anni and i was woundering how i could make it chatter or do i need a different vale? Thanks
liva2704
GTI forum regular
Re: Dump valve chatter
26 May 2012, 19:40 »
i thought it was the wastegate that chatters and not the dump valve?
rio_gti
"i'm not spending any money on it" Got a Hybrid!
27 May 2012, 13:53 »
It will chatter if it isn't working properly, as the chatter sound is the pressurised air is going the wrong way thru the turbo and it's the fins chopping the air and stalling..... No good for the turbo!!!!
Something along those lines anyway
2000 GTI 1.8t ARZ, S2000 filter, DSG intake, Forge 007 dv, Catch can, R-tech custom remap, 3" Supersize Silicone TIP, Powerflex dog bone, 'The Beast' FMIC, Ultimate delete, LCR fuel pump, 3" Turbo back, K03 hybrid, Ported Manifold, S3 injectors, 80mm maf = 280bhp 270lbft
dragonfly
27 May 2012, 14:55 »
Chatter is basically the turbo stallling.
daz veedub
Forum addict
Operation 1.8t bolf
27 May 2012, 21:30 »
if u want the tsssssh noise fit a induction kit
MBEEZY
28 May 2012, 18:23 »
I think if you fit the 007p the wrong way round or something along those lines it makes the chattering sound, and they cone filter does help it alot.
Mk4 1.4 soon to be agu =D.
clipperjay
Reply #6 on:
28 May 2012, 19:51 »
Buy a tape
http://www.golfgtiforum.co.uk/index.php?topic=170521.0
http://www.golfgtiforum.co.uk/index.php?topic=55336.msg427955#msg427955
Wayne
Sir Postalot
Reply #7 on:
28 May 2012, 20:39 »
Quote from: daz veedub on 27 May 2012, 21:30
Yep, mine is bonkers on the Carbonio kit
enyap
Reply #8 on:
31 May 2012, 10:45 »
just changed from a forge splitter dump valve to a 007p (reverse mounted) the noise wasn't much different on both until i changed the induction kit back to the standard airbox setup, now i don't hear a peep out of it
The garage
Dump valve chatter
