Author Topic: obd2 no communication to scanner  (Read 15086 times)
Offline BenGTI16v
« on: 26 May 2012, 15:33 »
Hi all, Im having  abit of trouble with my golf as the abs light has just come on  :sad: so I plugged it into a scanner and it came up with no communication. I did a bit a research and found out that if you have an aftermarket stereo fitted this can give you problems, so ive tried scanning it withoutit connected aswell with no luck. I have battery voltage to pin 16 on the obd2 port but I dont know what else to test.
Car is a 95 mk3 gti 16v and im using a snap on verus
Any help appreciated thanks.
Offline ttelracs
  • The Fettler
Re: obd2 no communication to scanner
« Reply #1 on: 26 May 2012, 15:47 »
Same issue !
Handbrake light came on so popped up to see my cousin who has a hand held scanner and could get no reading at all. It stated it was unable to communicate or no link detected. I too have an aftermarket head unit fitter, a Kenwood of some sort which it came with and wonder if this is why no joy ?
No answer though !
Offline BenGTI16v
« Reply #2 on: 26 May 2012, 16:22 »
I have tested some of the pins on the port and I have battery voltage to pin 16 a good earth at pin 7 I believe pin 4 in the k-wire which should give a voltage but only gives 0.01v
Offline BenGTI16v
« Reply #3 on: 26 May 2012, 16:40 »
Same issue !
No answer though !
Checked you brake fluid level? sometimes the little plunger thing for the senser sinks in the resovoir causing the light to come on.
Offline itavaltalainen
« Reply #4 on: 26 May 2012, 17:32 »
What OBD scanner are you using? Which cable? VWs of the mid to late 90s have OBD2 sockets but are not OBD2 compliant, hence you need a VW specific tool. Other than that might be a wiring issue....
Offline BenGTI16v
« Reply #5 on: 26 May 2012, 17:49 »
Ive used a snap on verus and a snap on ethos both didnt work but they could connect to another mk3 golf I had in at work but that was a 1.4 97 plate.
Offline Ess_Three
« Reply #6 on: 26 May 2012, 18:46 »
As far as I know, no Mk3 was ever fitted with a diagnostic line to the Stereo...it's just too early.
So changing the Head Unit won't cause you any problems.
..but gaining motorcycles.
« Reply #7 on: 26 May 2012, 19:51 »
It's not about a diagnostic line to radio. It's the speed signal for the gala function, if connected to some radios this can for whatever reason mess up comms with diagnostics. I suppose it can confuse the ECU.
Offline Ess_Three
« Reply #8 on: 26 May 2012, 20:01 »
Is there a speed signal in the radio wiring harness on the Mk3?
There ism't on mine.
I thought Gala came later on, with the Mk4?
« Reply #9 on: 26 May 2012, 20:58 »
All mk3s should have gala signal. Pin 1 on ISO connector should be that ;)
