Author Topic: Anyone used lemmiwinks???  (Read 2402 times)
Offline shaft69
« on: 25 May 2012, 23:07 »
Anyone tried using above, if so how good is it and is it easy to use??
MK4 1.8t bored/stroked 2.0lt AEG crank, 83mm supertech pistons, intergrated rods, ACL race brgs, Flowed large port head, Supertech valves, All ARP bolts, GTX2871r turbo, Tial wastegate, 3" pipewerx dp, REVO stage 3 tune, Direct port water meth, MORE TO COME!!! Ready to go racing
Owner of bndynamix ltd. BMW and mini specialist
184 Wallgate, Wigan
WN3 4AL
07966492823.
Offline Toby
  • Car - less
Re: Anyone used lemmiwinks???
« Reply #1 on: 25 May 2012, 23:07 »
Lemmi what?
Currently down under
Offline JoelBu
« Reply #2 on: 25 May 2012, 23:20 »
engine management software...
and im afraid not,
Mk4 1.8t, ko3s, miltek exhaust, JOM coilovers,
Offline shaft69
« Reply #3 on: 25 May 2012, 23:38 »
My nephew sent over link from states if i knew more about how to use it, set timing up for my water inj.
184 Wallgate, Wigan
WN3 4AL
07966492823.
Offline littco
« Reply #4 on: 26 May 2012, 06:50 »
Yes used it, it's a little ltd and only adjusts the adaption channels. You can increase a number of things 14 in total main ones are timing and rpm limit, has idle speeds etc etc. timing wise it adds / subtracts timing across the whole map rather than specific points like a remap would do. But good if you says add an fmic as you can a few degrees timing to make sure of cooler iats. Worth playing with and can be used with cheap eBay cable but it's not a substitute for a remap, I'd suggest it's best for using if you've had a remap and add a few upgrades and want to get a little more I guess you can call it a 1.5 remap if you have a stage 1
Offline shaft69
« Reply #5 on: 26 May 2012, 09:26 »
Which cable to be used on fleebay this one??
http://www.ebay.co.uk/itm/Serial-Port-RS232-DB9-OBDII-9-16-Pin-Cable-Lead-027-/230589847032?pt=UK_Diagnostic_Tools_Equipment&hash=item35b039d5f8
« Last Edit: 26 May 2012, 09:28 by shaft69 »
184 Wallgate, Wigan
WN3 4AL
07966492823.
Offline Scott D
« Reply #6 on: 26 May 2012, 12:14 »
this might be easier as can use a USB to OBDII / VCDS cable rather than serial port
http://unitronic-chipped.com/main/en/tuning/uni_setting.html
2003 1.8T GTI 180 - APR Stage I, S2000 Filter, R-Tech Supersize TIP, Bilstein B12 Suspension, 18" OZ Superleggera, Recaro Heated Leathers, US Spec Rear Lights, N249/SAI/PCV Delete
1.8T AUQ - 241bhp & 286 ft-lb
R-Tech Map, Forge FMIC, SFS Oversized TIP, Ported Manifold, Milltek Turboback non res exhaust, Forge 007p, N249 & N112 delete, SAI delete, S2000 Air Filter, Sachs clutch & Lightweight Flywheel
Offline topher
  • Administrator
  • fully functioning
« Reply #7 on: 26 May 2012, 13:29 »
im not sure if unisettings only works with unitronic software. either way you need to be confident in your datalogging skills before messing with engine adaptation channels!
Offline shaft69
« Reply #8 on: 26 May 2012, 16:21 »
[/qhttp://www.ebay.co.uk/itm/Black-VAG-COM-OBD2-OBDII-409-1-KKL-USB-Car-Diagnostic-Cable-Interface-Tool-UK-/250925077077?pt=UK_Diagnostic_Tools_Equipment&hash=item3a6c4cd255uote]
Also this fleebay one??
184 Wallgate, Wigan
WN3 4AL
07966492823.
Offline shaft69
184 Wallgate, Wigan
WN3 4AL
07966492823.
