Author Topic: advice do's or dont's dump valve  (Read 3126 times)
Offline matping
  • MK1 20vT MK5 GTI T
« on: 25 May 2012, 22:21 »
got a brand new 007 recirc dump valve in the shed that was going to go on my mk4  but ill put it on the mk5 in the morn ! any issues or known problems? fitting easy??
Offline Rhyso
Re: advice do's or dont's dump valve
« Reply #1 on: 26 May 2012, 07:09 »
Fairly sure it wont fit so pop yourself down to VW and get their latest revision.  Its about £50 and is a straight swap.
Offline Nodz
« Reply #2 on: 26 May 2012, 15:15 »
Rev D is roughly £40 odd and Rev G is £34. Rev D is newer than G but there is a big discussion on which one is best
Offline matping
« Reply #3 on: 26 May 2012, 15:30 »
oh right not come across this before  so are the rev D and G  both recirculating? as the mk4 needed a recirc dump valve? or can i go for a atmospheric? and its a VW dealor part ?
infact would you send me a link so that i know what im looking for ??
« Last Edit: 26 May 2012, 15:36 by matping »
Offline Rhyso
« Reply #4 on: 26 May 2012, 15:50 »
You can get a Forge dv but its more expensive.  The latest dv is more than adaquate for a standard and a mapped car :smiley:
Stick with a recirculating; it does it for a reason  :wink:
Offline Nodz
« Reply #5 on: 26 May 2012, 20:28 »
Both recirculating. Rev A, B, C and G have diaphragms and are prone to splitting. Rev D is a piston type and is ment to be more reliable. But now people are saying that Rev D are prone to failure aswell and G is the better one to get but with rev G being roughly £34 and Rev D being £43 (iirc) its best just to treat it like a serviceable part
Bit of reading for you:
http://www.mk5golfgti.co.uk/forum/index.php/topic,47984.0.html
http://www.my-gti.com/476/volkswagen-oem-diverter-valve-upgrade
