Author Topic: mk 2 2.0 info needed  (Read 3155 times)
Offline dubslug
« on: 09 June 2005, 16:25 »
right guys i got myself a 2e bottom end (2.0 8v)ive got a spare head to rebuild etc wot else do i need to make it all fit??
head set from mk 2??
head gasket from mk 2 or 3?
cam belt from 2 or 3?
fly wheel use mk2 or 3??
clutch mk 2or 3?
anything else u can think off??
cheers guys
ah also will a kjet gearbox fit this engine??
1992 pearl grey 8v
Offline jimbo
Re: mk 2 2.0 info needed
« Reply #1 on: 09 June 2005, 22:27 »
you will need the head gasket for the 2e engine as the bores wont be right otherwise.
gasket set for mk2 head. (is it a digifant your building?)
cam belt for 2e engine
i think you need to use the mk2 fly wheel and clutch co of the starter and gearbox.
keep us posted on how you go matey  :smiley:
aye up me duck!
Offline dubslug
« Reply #2 on: 13 June 2005, 11:10 »
cheers dude,
if anyone else has any info of any kind pleasefeel free to drop me a line as i dont want no no surprises when i start rebuilding the engines lol
1992 pearl grey 8v
Offline Ryan
  • Scotland
« Reply #3 on: 13 June 2005, 19:02 »
if you drop me your email address as i cant get it through the thing in the forum i have a few bits off info along with a basic step by step guide
ryan :smiley:
WANTED:: 16v crankshaft pulley and rear windescreen washer bottle
Offline knobby
« Reply #4 on: 03 September 2005, 17:35 »
Hi Mate...
Your only in Basingstoke.. Go see Martin at GFS in Farnham.. This guy knows so much about VW's. Its where i've got all my bits from.
You on MSN messenger? add me.. dave@getripped.co.uk
cheers
Knobby!
Old VW's never die...they just go faster!
Offline Mr V Wagon
« Reply #5 on: 03 September 2005, 20:04 »
If any of you MK2 GTI digifant owners are trying to get around the dizzy problem, i've got a new Bosch 2E/ABK dizzy with the bigger gear and base, ideal for a digifant MK2 GTI 2.0 conversion.
I'm in N.London and i'd want 45 quid - 55 if posted  :wink:
Mr V - 2.0 8v 14.6 @ Pod - N.London Elite1000 Ace Cafe -  E1K Forum
Offline knobby
« Reply #6 on: 03 September 2005, 20:06 »
why would we have a problem?
Knobby
Offline Mr V Wagon
« Reply #7 on: 03 September 2005, 20:12 »
Doesn't the standard mk2 GTI dizzy have a smaller base and gear than the one needed in the 2.0 block?
Offline knobby
« Reply #8 on: 03 September 2005, 20:35 »
so ur saying it cant be timed up with the standard dizzy? Ummm
Knobby
Offline Mr V Wagon
« Reply #9 on: 03 September 2005, 20:58 »
If I remember properly, the 1.8 GTI has a smaller base and gear than the 2.0 needs. Double check me but to get around this you need to buy a spacer ring and a bigger gear - TSR can supply them.
I've got a 2E dizzy because i was going to use it for my MK1 2.0 conversion but i didn't do enough research and found the 2E dizzy doesn't have a vacuum unit the k-jet set up needs! You don't need the vacuum unit on the digifant system because it's controlled by the ECU.
The wrong fecking dizzy cost me 90 quid! So i'm trying to flog it to scrap some money back! lol!
Oh, i'm new to the forum. Thought i'd sign up today :smiley:
