Author Topic: New Dodo Juice Product Launch  (Read 2109 times)
Offline waxamomo
« on: 25 May 2012, 10:23 »
The long awaited May product launch from Dodo Juice has happened and has got us all a little bit excited, some fantastic products were launched yesterday, all (bar the clothing which will be added later) are on the site and available to order :thumb: Products are due with us Monday :thumb:
So, what's new?
[COLOR="Lime"]Dodo Juice Supernatural Micro Prime [/COLOR]250 ml @ £14.95 or 500ml @ £24.95
Most pro detailers have a bottle of Lime Prime and most amateurs having tried it. It's well loved, but some users found that if it wasn’t worked enough on soft paint then the abrasives wouldn’t break down and could mar the paint slightly; not an issue when it is fully worked or used on hard paint, but it was a small issue nevertheless. Lime Prime Lite was an alternative, but was oil heavy and could be tricky to use on some paints, so we created this Supernatural pre-wax cleanser and ultra-fine polish… Micro Prime. Like Lime Prime, so nice and workable by hand or machine, but with even finer micro-abrasives. This allows it to clean and polish softer paints without marring, without the tricky application and oiliness of Lime Prime Lite – so you get the best of both worlds. What’s more, it can cut a treat as well, restoring our VW Golf Mk2 solid red sun roof panel back to red (from pink) with minimal filling. Those particles are small but they’re mighty. We welcome testing vs similar products and are interested to see whether people find it better than Lime Prime. Priced at 14.95 GBP RRP for 250ml and 24.95 GBP RRP for 500ml.
[COLOR="lime"]Dodo Juice Low On Eau[/COLOR] - 250ml @ £8.95 or 500ml @ £16.95
This is our rinseless wash, brought out to beat the hosepipe ban where it still exists in the UK and for those customers who live in flats (without their own outside tap) or for showgoers who need to spruce up their cars on-site. Optimum No Rinse (ONR) is the most famous competitor. Our version is a lubricious yellow liquid (smells of pineapple and apple) that cleans panels before they get buffed/dried to a high shine (so there is no rinse stage). Lubricants help prevent contamination scratching the car although we recommend it is used on lightly soiled vehicles only. The water behaviour due to these lubricating/glossing oils is pretty impressive… check out the water sheeting immediately after (although the irony is you may not have access to a hose!). Priced at 8.95 GBP RRP for 250ml and 16.95 GBP RRP for 500ml. Dilutes 1:200 (similar to ONR).
[COLOR="Lime"]Dodo Juice Supernatural Acrylic Spritz -[/COLOR] 250ml @ 12.95 or 500ml @ £22.95
This is a spray sealant or ‘protection detailer’, like Red Mist – but it’s WATER based, so there’s no solvent to attack fresh wax layers and it’s a high-performance acrylic rather than a more traditional sealant recipe. Whilst Red Mist was giving about 4-6 weeks durability/longevity, the longevity of this can be measured in months… we reckon it is far closer to a normal liquid sealant, and offers perhaps 3-4 MONTHS of durability, maybe more. It won’t beat Supernatural Hybrid, but for a quick spray product it does amazingly well. Given the non-interference and relatively low price and this should be a great product for those wishing to apply a sealant layer to bodywork, trim or wheels (it suits almost all surfaces) or for those wishing to add an interim ‘top up’ layer of protection to their waxed/sealed vehicle. Priced at 12.95 GBP RRP for 250ml and 22.95 GBP RRP for 500ml.
[COLOR="lime"]Dodo Juice Supernatural Carnauba Glaze -[/COLOR] 500ml @ £14.95
For those who want a natural quick detailer or glaze, we created this high carnauba solids spray. It is silicone-free and gently cleans a panel before leaving behind a layer of high grade carnauba wax. This won’t have the kind of durability/longevity of a spray sealant like Acrylic Spritz, but it won’t be far off Red Mist. A great glaze and quick detailer for cars that sport carnauba wax finishes. Priced at 14.95 GBP RRP for 500ml.
[COLOR="lime"]Dodo Juice Supernatural Tyre Dressing [/COLOR]- 250ml @ £12.95
Tyromania is a bit too matt in terms of finish for many users, so this is the answer. Supernatural Tyre Dressing. It leaves a satin finish on tyres and is a pleasure to work with. A mild water-based emulsion that dries to a finish that gives no sling or splatter. ‘Just the right amount of shine’ rather than an artificial wet look. Priced at 12.95 GBP RRP for 250ml.
[COLOR="lime"]Dodo Juice Supernatural Wheel Sponge[/COLOR] - £8.95
The Supernatural Sponge has been a real success and showed that detailers can, and do, use sponges. This is a black foam version shaped to fit the curved rim of wheels, and with pointed ends that can go into wheel spokes more easily. So now you don’t need to get your Supernatural Sponge cross contaminated with wheel grime… use the Supernatural Wheel Sponge for those dirtier areas. Priced at 8.95 GBP RRP.
[COLOR="lime"]Dodo Juice Supernatural Microfibre Cutting Pads[/COLOR] - 80mm @ £7.95 or 130mm @ £9.95
Similar to the Meguiars’ microfibre DA cutting pads, designed to give more bite to orbital machine polishers. In 130mm and 80mm sizes to suit standard 125mm backing plates and 75mm spot plates. Priced at 7.95 GBP RRP for 80mm and 9.95 GBP RRP for 130mm.
And the best news of all........We are continuing our Birthday Celebrations for another weekend :D
