Author Topic: Widetrack and final offset  (Read 4498 times)
Offline Dave_IOW
« on: 25 May 2012, 00:09 »
Going widetrack off a mk3 GTI so will be 5 stud, and buying some BMW fitment wheels.
The zimmer wheels have an offset of 47, will they fit with adaptors, or will they have to be re-drilled?
The car has the small arch kit on it, will this be enough to hang out over the tyre tread? Don't particularly want stretched tyres.
Project: Mk2 20vT trackslag
Daily: Mk2 GTI typ19
Offline oakgreengolf
  • CAR FOR SALE PM FOR FURTHER INFO
Re: Widetrack and final offset
« Reply #1 on: 25 May 2012, 17:11 »
Offset of a standard wheel is around 37, wide track gives you another 10mm if I remember correctly. So in total your looking at roughly 20mm wider than what you have now. That's without the adaptors too.
Offline Dave_IOW
« Reply #2 on: 25 May 2012, 19:00 »
Pretty sure the number gets lower the further away from the car you get, so an ET47 wheel, with 25mm spacers, would end up at ET22 which I believe is fine on a mk2.
How this is affected by, in particular, the mk3 gti wide track option I'm unsure... Sure someone on here will have done it     :smiley:
Offline murraymint
« Reply #3 on: 25 May 2012, 20:04 »
Have you looked on the vwGolfmk2 forum? Lots of info on there
josh
« Reply #4 on: 25 May 2012, 22:11 »
Going to be really tight for clearance.
Offline danny_p
« Reply #5 on: 25 May 2012, 23:15 »
dosent have to be 5 stud  you can use 4 stud hubs with the mk3 wishbones, driveshafts and arb's,  of press 4 stud hubs into the mk3 bearings carriers
all the VW's have gone bar 1.
Offline Dave_IOW
« Reply #6 on: 28 May 2012, 23:49 »
So I can use the whole mk3 16v setup so I can fit AGU and still retain 4stud?
Offline JC
  • Back in the North.
« Reply #7 on: 29 May 2012, 07:45 »
yet more decisions . . . . . . . . .
Offline Dave_IOW
« Reply #8 on: 29 May 2012, 11:22 »
Messing with my emotions this is.    :grin:
Offline Diamond Hell
  • Opinions я Us
« Reply #9 on: 29 May 2012, 11:24 »
 :grin:
