Author Topic: 16v question erm help  (Read 4833 times)
Offline mush
« on: 24 May 2012, 21:22 »
Spent more time on the golf today, so today I flushed the coolant then concentrated on that really bad smell I can't seem to get rid of
I noticed under the steering colum there's a pipe that leads to what looks like the back of the speedo that's leaking. Had the scuttle panel cover off and it passes through down to the gearbox and sits behind the clutch cable.
So I'm pretty sure this is my smell as its dripping down onto the steering colum and stinks
Question is what is this pipe and are they prone to leaking? Also the pipe was right down near the bottom of the engine and sure it should run on long the top.
Got 2moz off so cracking on with it wouldn't mind some advice please guys
« Last Edit: 26 May 2012, 23:47 by mush »
MK2 golf 16v :-)
Re: 16v question erm help
« Reply #1 on: 24 May 2012, 21:42 »
That I am sure is your speedo cable.
Offline mush
« Reply #2 on: 24 May 2012, 21:51 »
It does look and feel more like a cable but its pi**ing oil from the back of the clocks. Does oil run to the back?
MK2 golf 16v :-)
Offline molegti
« Reply #3 on: 24 May 2012, 22:05 »
No but it can siphon it from the gearbox that would explain the smell
Offline tomp
« Reply #4 on: 24 May 2012, 22:05 »
Take a picture of it and someone will tell you what it is!
Oil doesn't run to anywhere in the back... Shouldn't be running out the clocks for sure
Offline tomp
« Reply #5 on: 24 May 2012, 22:08 »
I'd go with that, never seen it happen but gearbox oil smells disgusting and the speedo cable goes where you described....
Offline mush
« Reply #6 on: 24 May 2012, 22:22 »
Dam this doesn't sound good, so I've ran it along the top of the engine bay and with it hanging down before I'm thinking its dragging crap up from may be a previously over filled gearbox. This is so strange using my blackberry but I'll try getting a picture up 2moz. And yes its really smelly not pleasant to drive my mrs won't even get in the car with me :-(
MK2 golf 16v :-)
Offline X4MGS
  • VAG Parts SNOB!!!
« Reply #7 on: 25 May 2012, 00:16 »
There was a case on here before and thats what was happening, the cable was drawing up GB oil and peeing it all over the car...
I seem to remember it was the seal around the box and a new cable fixed it - BUT don't hold me to that do a search & you have to be careful when swapping the cable as there is a small part that can fall off into the box... I'm Not a Mechanic but it's what I've read....
For More Info Click To See;
Offline raferackstraw
« Reply #8 on: 25 May 2012, 01:24 »
try a new speedo cable and also check gearbox breather is clear [ small black cap infront of gear selector rod on gearbox ]
wayne gardner smokes one rothmans too many
500cc 2stroke bad for ya health
Offline mush
« Reply #9 on: 26 May 2012, 09:09 »
i havent had chance to look at this again yet but it really needs sorting, (your Right guys its the speedo cable)
with it being a nice day yesteday i swapped out the rear windscreen as the other was scratched to bits, not an easy job at all took 5hours to remove old one and replace for new one  :laugh:
MK2 golf 16v :-)
