Author Topic: Anybody had ignition barrel problems with starting  (Read 1449 times)
Offline spudboy6
  • Just like a golf ......
I have an issue and I wonder if anyone else has Hadyn problem ?
You know when you get in the car . Turn to key to start it the car goes to turn over and stops and doesn't start all the ignition lights dim , then you wiggle the key and then it fires up , so something in
The barrel is faulty ?
Many thanks guys :)
Offline Screech16v
  • MK3 20vt AGU
Re: Anybody had ignition barrel problems with starting
« Reply #1 on: 24 May 2012, 18:52 »
Switch on the back of the barrel matey,£5 off ebay  :smiley:
Offline spudboy6
« Reply #2 on: 24 May 2012, 19:09 »
Thanks mate just being a bit simple what should I search for ,
Just looked for ignition switch is that right ?
Thanks
Offline Shady Pioneer
  • graphic designer.
« Reply #3 on: 24 May 2012, 19:11 »
Most likely what happened to mine buddy. Here is a link to how I sorted it:
http://www.golfgtiforum.co.uk/index.php?topic=191694.msg1801191#msg1801191
Offline spudboy6
« Reply #4 on: 24 May 2012, 19:24 »
Cheers for that pal, is this what I need to buy ?
Look at this on eBay:
Ignition Starter Switch VW Golf Mk3 ALL MODELS replaces Black or White switches
http://bit.ly/JGEogG
Offline Screech16v
  • MK3 20vt AGU
« Reply #5 on: 24 May 2012, 19:27 »
Thats the one .
  • graphic designer.
« Reply #6 on: 24 May 2012, 19:28 »
Assuming you have the same issue as I had then yes. Wiggling keys is not ideal that's for sure.  :grin:
It's just a pain to do, but even I, MK3 moderator and infamous car-f**k*r-upper managed to do it by myself.  :cool:
