Author Topic: Few question.  (Read 2150 times)
Offline search
Few question.
« on: 24 May 2012, 16:12 »
First is, Why would my car make some strange noise when steering even dry steering i get this kinda electrical noise ( almost like a hissing whine noise)
second is cambelt never done this before would it be easy for a first timer to follow a step by step haynes manual guide or should i leave it to the pros?
Golf mk3 1.4 (sold)
Golf mk2 1.3 (sold)
Golf mk3 1.6
Offline murraymint
Re: Few question.
« Reply #1 on: 24 May 2012, 17:11 »
Id say that's the power steering pump, mine does it close to full lock
josh
Offline tweed
Re: Few question.
« Reply #2 on: 24 May 2012, 17:16 »
That will be your power steering pump. Normal sound!
Cam belt totally depends on your mechanical abilities. If you don't know what a ring spanner is forget it.
There are guilds on here but you should know that all ready Search!
Offline Bandit127
Re: Few question.
« Reply #3 on: 24 May 2012, 17:51 »
Based on an earlier conversation here - I think you should be able to explain what TDC is.
If you can do that then I think you are have the basics.
If you can't then I think you need to learn what TDC is before starting.
Good luck.
Offline search
Re: Few question.
« Reply #4 on: 24 May 2012, 22:36 »
if you think about it, iv just help some poor sod who will search and find this topic lol.
so yeah pretty much leaving cambelt to the pros.
Golf mk3 1.4 (sold)
Golf mk2 1.3 (sold)
Golf mk3 1.6
Offline Bandit127
Re: Few question.
« Reply #5 on: 24 May 2012, 23:13 »
I will pretty much tackle anything mechanical and have no worries about an 8V cambelt. But I will admit that my Omega 3.0 V6 got done by the garage so no worries from me about subbing that job out. 2 cams, 2 tensioners and half the engine to remove to get to it... a horrible job and it was money well spent at the time.
Anyway - here is an animation of the 4 stroke cycle that explains TDC. Think about what would happen if the valves open and close at the wrong times in this vid. The worst case is that a valve is still open when the piston reaches TDC. This would (at least) bend the valve.
http://www.youtube.com/watch?v=IYWUWMmimjQ&feature=related
Since the timing of the valves are tied to the pistons by the cambelt, you can imagine that fitting a cambelt wrongly could have severe consequences... In fact, I think the animation shows the piston clobbering the exhaust valve that failed to close at the end of the cycle (might be my old eyes...)
The Haynes manual will take you through, step by step, how to avoid that and get the timing between the pistons and valves spot on though. If you can follow the video you can understand how important getting the timing right is. The rest of it is just nuts and bolts - no harder than replacing a fan belt or aux belt really.
« Last Edit: 24 May 2012, 23:20 by Bandit127 »
Offline gti gaz
Re: Few question.
« Reply #6 on: 25 May 2012, 08:32 »
Power stearing pump for sure my gti and tri do it, and cam belts on these are not to bad unlike the 1.8t passat I haft to do soon not looking forward to whole front off car off  :grin:
 Any one in cornwall lets sort more meets!!!!
Offline search
Re: Few question.
« Reply #7 on: 25 May 2012, 16:04 »
cool cool so normal sound for the pump then i assume.
Golf mk3 1.4 (sold)
Golf mk2 1.3 (sold)
Golf mk3 1.6
Offline stainesy
Re: Few question.
« Reply #8 on: 25 May 2012, 16:15 »
yeah mine does it aswell and so does my steering column  :grin:
Gavv8
Re: Few question.
« Reply #9 on: 25 May 2012, 21:50 »
Cambelts are not too bad in the main providing you make sure you have everything you need before you start (including any special tools you might need) and allow plenty of time to do it, look online to see if there any specific things you need to know as some cars are prone to seized bolts/awkward to remove ancillaries/specific ways to lock cams,crank pulleys etc.
