Author Topic: Air leak 16v  (Read 1244 times)
Offline Loynes
Air leak 16v
« on: 23 May 2012, 21:36 »
Does this mixture adjustment screw have an o ring seal?  Mine is leaking air,  sprayed some choke cleaner on the hole where the mixture screw is and it goes bonkers. If I push down on the adjuster and it maintains the idle and when I let go it hunts again. Any ideas. Getting there now timing sorted just this last air leak and then we are sorted. Track day here we come!!!
Offline raferackstraw
Re: Air leak 16v
« Reply #1 on: 25 May 2012, 01:26 »
yes it should have an o ring unscrew and pull it out to check
wayne gardner smokes one rothmans too many
500cc 2stroke bad for ya health
