Golf mk4
Wazzzer
Does this do what it says? or just a gimmick, also....
Topic: Does this do what it says? or just a gimmick, also.... (Read 1055 times)
Nino
22 May 2012, 21:41 »
I came across this today....
The writeup says...
This kit allows you to relocate the diverter valve from the hot side of the turbo to the cold side of the intercooler on the VW Golf, Jetta 1.8T engines of 150 - 180 HP. For the 210/225 versions of this engine please see FMDV225RLK.
By relocating the valve in this way there are two benefits. Firstly, due to operating in lower temperatures the longevity of the valve is increased. Secondly, after relocation, the air that is recirculated back into the intake tract to the turbo will be cooler. Cooler air has a greater density. The greater the density of the charge mix in the cylinder the more power generated on combustion.
Also came across this...
The Splitter is a truly remarkable valve that gives a combination of blow off and recirculation valve operation all at the same time and has been specifically designed for the many turbo engined applications that operate metered airflow management systems.
This means you get all the noise of the blow off valve whilst retaining the compatibility with the recirculation requirements of the engine management system. As a bonus we also offer the ability to convert the valve to recirculation only mode for those times when stealth running is required
My question is, does these do what they say? Reaosn i ask is because A i havent seen anyone that has done this mod with the turbo pipe & as far as I was aware the only DV's worth using are the 007 or 008
Images and information taken from
http://www.revolution247.com
Like my badge? Get one here:
https://www.golfgtiforum.co.uk/index.php?topic=291134.0
VW Car history
- Mk3 1.8 GL - Silver - 5 door, Mk4 1.8t - Silver - 3 door, Mk4 R32 - Black - 5 door, Mk5 GTi - Black - 5 door, Mk4 R32 - Deep Pearl Blue - 3 door, MK6 2.0 TDI - Graphite Blue - 5 door, MK7 GTD - Solid Black - 5 door.
Current
- MK6 GTi Edition 35
Wayne
Sir Postalot
Re: Does this do what it says? or just a gimmick, also....
23 May 2012, 08:03 »
Running the splitter valve will cause issues, stick with the 007 /008
Wazzzer
Moderator
10k hero
Golf GTI 1.8T AGU
23 May 2012, 19:12 »
The theory behind the relocation sounds good but I can't see it making much difference in the real world
1999 1.8T: R-Tech remap - 225bhp/256lb/ft : K03s : THS FMIC : THS PCR pipe : 2.5" stainless exhaust : THS FR3 Engine mounts : G60/VR6 clutch : Calibra Yellow injectors : VR6 MAF : Devils Own WMI : Forge 007p : Carbonio CAI : Leon Cupra R Brembos : FK AK Street coilovers : Votex skirts : Anniversary front : click --->
http://www.golfgtiforum.co.uk/index.php?topic=92175
cullygti
23 May 2012, 22:09 »
i have seen this done a few times but just cant see the point in the cost and hassle of it
Nino
24 May 2012, 01:03 »
Quote from: Wayne on 23 May 2012, 08:03
Thought as much ta for that
VW Car history
Current
Golf mk4
Wazzzer
