Author Topic: oil pipe to sump  (Read 1174 times)
Offline monty9120
oil pipe to sump
« on: 22 May 2012, 16:22 »
hi all. i changed the sump on my 1.8t golf yesterday. the oil pipe was taken off and there was no sign of any gasket.
i put it all back together. now im getting a little leak. i have tightened it as much as i dare and its still dropping a little. maybe a small drop a minute.
its not a big deal but a new sump i expect no leaks. has anyone used a instant gasket on this part. i would have thought how tight it is it wouldnt leak :(
Re: oil pipe to sump
« Reply #1 on: 22 May 2012, 16:37 »
Use a little instant gasket or make a gasket from gasket paper.
Offline rio_gti
« Reply #2 on: 22 May 2012, 17:12 »
I done this too!! It's still on the old sump stuck flush!! Get the stanly blade on it to get it off and reuse!!!
Offline monty9120
« Reply #3 on: 22 May 2012, 17:47 »
there was no gasket on mine. it was metal to metal.
i will drop the oil out and put some instant gasket on.
hopefully this will finally sort it its leaking more now haha  :smiley:
Offline dan2252
« Reply #4 on: 22 May 2012, 23:21 »
yeah there should be a gasket think i paid 1 or 2 quid from work for mine, it looks like theres no gasket but there will be. i used instant gasket but it still leaked so just fitted a gasket and its been ok now for 5 month or so :) also if you do becarfull dont put loads of sealant on dont want it drying and then going into the sump then into pick up pipe
MK4 golf 1.8 turbo agu :)
Offline monty9120
« Reply #5 on: 23 May 2012, 18:47 »
im kinda annoyed now. i dropped the oil out again. refitted and put gasket on. smeared a small bit of instant gasket and tightened it up.
its still leaking. it looks to me in the middle between the 2 bolts its not pulling in flush. i cant tighten it anymore in case i thread the bolts. any ideas?
Offline rio_gti
« Reply #6 on: 23 May 2012, 18:51 »
did you put paper gasket aswell as instant??
Offline monty9120
« Reply #7 on: 23 May 2012, 22:11 »
it was a thin metal gasket that was on the old sump. i only smeared a small amount of instant gasket. it just seems in the middle theres a slight gap (maybe reflections from the gasket) ill try and take a picture. other then this the cars running fine so would like to sort this once and for all
Offline monty9120
« Reply #8 on: 24 May 2012, 16:35 »
f**king hell in the garage it goes. one of the oil return bolts has snapped clean off. i wish i had some luck with this car, hopefully the garage sort it as i need a ramp
Offline monty9120
« Reply #9 on: 26 May 2012, 13:26 »
ending up buying a second sump. the 2 hidden bolts were easy now ive done it a few times :)
now all good finally with no leaks. for some reason all the sump nuts have a groove at the end and they dont seal great. i managed to get one without the groove and no small leaks  :cool:
