Author Topic: Air Con Pressure Switch  (Read 1414 times)
Offline Kerrse
« on: 22 May 2012, 14:23 »
I have been having problem with the Mk4 air con, it was re-gassed a while ago & worked fine for a couple months then stopped working again.
 It showed the climate control was a fault so replaced that & still did not work, it now says the air con pressure switch is the fault but the parts dept at my local dealer are not sure which part it is i need i have the parts diagram can anyone tell me which part is the pressure switch.
(link gone as must have had a time limit on it)
thanks  :cool:
« Last Edit: 23 May 2012, 07:21 by Kerrse »
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: Air Con Pressure Switch
« Reply #1 on: 22 May 2012, 17:29 »
I've got a receipt for a new one somewhere, will see if I can find it
You know where it's located?
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #2 on: 22 May 2012, 21:39 »
I think this is the right number mate
1J0 959 126
Offline Kerrse
« Reply #3 on: 23 May 2012, 07:20 »
Thanks Wazzer very appreciated will give them a call today  :cool:
Offline Kerrse
« Reply #4 on: 23 May 2012, 07:32 »
Just found that on the diagram but it comes up as
1KO 959 126A Thrust Sensor ? I did a google search seems to be the same part
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #5 on: 23 May 2012, 18:54 »
just going through my receipts now mate...
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #6 on: 23 May 2012, 19:02 »
bang on mate :afro:
Offline Kerrse
« Reply #7 on: 24 May 2012, 07:31 »
bang on mate :afro:
Thanks for your help the new part number is now 1KO 959 126D apprently had changed again, got it now £51 it cost  :shocked:
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #8 on: 24 May 2012, 20:49 »
holy sh!t! Mine was only £36 (it was about 4 years ago though)
